H.G.P.'s Avatar
Oil change, where's most of the oil drain from? Case drain or Sump tank?
Wondering if most of the oil (or equal amts.) is suppose to come from the oil tank or the bottom case/drain? Does it matter? 69 911E.
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 10-21-2006, 07:34 PM
bruni911's Avatar
s
Old 10-21-2006, 07:46 PM
Try not, Do or Do not
Henry Schmidt's Avatar
When you first shut it off, there should be more oil in the tank.
As it sit the oil will drain from the tank into the bottom of the engine.
That is why some engines leak when they sit but not if you drive them. This is especially true about oil return tube leaks
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-21-2006, 08:37 PM
H.G.P.'s Avatar
Thank you Henry very much!
1969 911 E Coupe
Old 10-21-2006, 10:08 PM
