-   -   Quick "can I remove this" question (http://forums.pelicanparts.com/porsche-911-technical-forum/310367-quick-can-i-remove-question.html)
Porsche virgin 10-18-2006 01:59 PM
Ya' know the lower valence between the wheels on '74-'89 911s with the rubber strip? Such as in this car?
http://forums.pelicanparts.com/uploa...1161205017.jpg
Is there any reason I can't/shouldn't remove it? I guess it protects the oil lines, but I prefer this look:
http://forums.pelicanparts.com/uploa...1161205055.jpg
TIA
Superman 10-18-2006 02:05 PM
I prefer that look also, and my rocker panels are leaning against the wall of my garage. I don't believe they do much of anything to protect the oil lines. From a side-impact maybe. Pretty questionable. I say they are purely cosmetic. And ugly. I would also say that there are a few screw holes that should be plugged and sealed against the weather once you remove the rocker panels. I think those screw holes penetrate the side-tunnels.
Bill Verburg 10-18-2006 02:11 PM
If you remove them your aero #s will be worse
masraum 10-18-2006 02:41 PM
You can remove them, but there will be some filling and smoothing that needs to be done to get the car to look as smooth as the second photo. If you aren't concerned about that, then no problem.
lov2fly 10-18-2006 02:51 PM
Car looks great as is! Get of the computer, drive and have fun.
randywebb 10-18-2006 06:09 PM
To get a visual of why Bill makes that comment, take them off and go for a high speed drive in the rain. You'll see that air (and dirty water) flow _up_ the sides of the car.
But hey - it's a Porsche - why let form follow function?
midlife 10-18-2006 06:17 PM
I took mine off, and welded up the holes as part of my re-back-date project.
I like the look.
ianc 10-18-2006 06:57 PM
Oil lines on the passenger side look pretty unsightly with them removed.
ianc
oneblueyedog 10-18-2006 07:19 PM
What about Carrera 2/4 side skirts?http://forums.pelicanparts.com/uploa...1161224280.jpg
klaucke 10-18-2006 08:10 PM
Agreed, but perhaps more important for the street, his oil temps will likely be better.
Scooter 10-18-2006 09:13 PM
Please, no.
Porsche virgin 10-19-2006 06:19 AM
Wow. I didn't think I'd get this many opinions! BTW, neither car is mine.
My car is mainly used for autox, occasional street use, and I hope to get more into DE next year (had my first taste last month).
The aero aspect isn't too much of a concern. It wouldn't matter at autox speeds, and I'm not going for time during DE events.
The reason I'd take it off is because I like the old, cleaner look.
That said, I'm lazy and not comfortable with the "patching" and "filing" work that would need to be done to make it look clean and smooth.
If I take them off, I suppose the black rubber strip would be hard to put back on, so there would be no going back.
http://forums.pelicanparts.com/uploa...1161263738.jpg
Bill Verburg 10-19-2006 06:26 AM
If oil temp is the problem the solution is usually oil cooler upgrade.
Porsche virgin 10-19-2006 06:32 AM
Funny you mention this because I'm in the process of researching this very topic. I have the 28-row brass cooler. My thought is, if I upgrade to the late model cooler, I should get a fan at the same time. My big worry about overheating is sitting in traffic on a hot day, with no air passing over the cooler. I'm considering the entire Elephant big mouth cooler and fan upgrade.
Bill Verburg 10-19-2006 06:39 AM
That would be a nice upgrade.
Superman 10-19-2006 06:57 AM
Glad you brought this up. In the olden days, when they made beautiful race cars, the sides of the cars had an airplane fuselage look. With the rockers removed, my car now has this look. Yes, they now know that the ideal shape for aerodynamic purposes is that of a friggin' BRICK. If the speed limit in my area were 160 mph, then I might consider driving a BRICK.
No the rubber part is not impossible or even difficult to reinstall. I like the look of the oil lines. Next step is to do something about the ugly bumpers.
My rear valence is also removed. I had it off, and could not think of a good reason why I would put it back on. Now, if it were a girl's car, that would be different.
Porsche virgin 10-19-2006 07:04 AM
No, thanks! Not on an open highway with my RA-1s!
Besides, my car is dirty as hell already. A little more wouldn't be noticed!
afterburn 549 10-19-2006 07:22 AM
remove the rear seats and rockers you will loose 20 lbs !!!! ( according to my scale) and thats a good reason for a delete -if your are staying under 150 mph
randywebb 10-19-2006 12:53 PM
re lazy -- too bad you can't just paint it white or put some FG in there and paint that white
- you're really after the look, right? and at the lowest possible effort?
Porsche virgin 10-19-2006 01:04 PM
What's FG?
And yes, lowest possible effort is good, when it comes to cosmetic things. Mechanical stuff is different.
Bill Verburg 10-19-2006 01:07 PM
the least effective weight to lose is from low and to the middle of the car.
If you want to diet, do it effectively. Start at the muffler and both front and rear bumpers.
randywebb 10-19-2006 03:08 PM
I agree - I suggested fiberglass (FG) 'cuz it is cheap and can be painted easily (rubber can't I don't think) - not b/'c it is light...
Formerly Steve Wilkinson 10-19-2006 04:24 PM
I recently removed mine, for the weight-saving. Plugged the holes with stainless-steel screws, did some filling and sanding, repainted the area and finally polished the scheiss out of the now-exposed brass oil lines. Frankly, I love the functional, locomotive look of the exposed lines. No big deal, they're not that obvious, but it's sort of saying, "We don't need no phony vanity panels to cover up the workings of this car."
Makes me think of so many modern cars with really lovely, sophisticated engines that are entifrely covered with plastic panels designed by dishwasher stylists. Yes, I know that some of it is for noise-damping, but does it have to look like a kitchen appliance rather than a 400-hp, four-cam, 48-valve, twin-turbocharged gas engine?
Porsche virgin 10-19-2006 08:10 PM
Steve, got a pic?
Randy, fill the holes with fiberglass?
jwetering 10-19-2006 08:28 PM
oops
jwetering 10-19-2006 08:29 PM
oops again
jwetering 10-19-2006 08:30 PM
I like the look without the rockers, exposed oil lines and all, but yes some people (like my wife) consider the whole naked look a little "ratty", especially with the unpolished oil lines and the open holes in the chassis. OK, I won't disagree and overall the 74-89 rockers are not that bad to look at, especially compared to the 964 rockers that came after (MHO).
Here's mine. Again, I think it's an improvement...it's retro. Perhaps this year I''ll take the oil lines off and polish them and maybe bondo up the holes etc.
http://forums.pelicanparts.com/uploa...1161314681.jpghttp://forums.pelicanparts.com/uploa...1161314735.jpghttp://forums.pelicanparts.com/uploa...1161314784.jpg
randywebb 10-19-2006 09:15 PM
No - I meant find something made of FG that is like the rubber strip you want to remove - somethng to interrupt the air flow up the body -- it will also keep mud off the doors and cover the holes.
Might try going thru the GT racing catalog. If it was me I'd just elave the rubber. But it ain't me...
Porsche virgin 10-20-2006 08:19 AM
Jasper, looks great. Could I trouble you for a close-up pic of the holes?
Formerly Steve Wilkinson 10-20-2006 08:28 AM
I suppose you can get real fancy with the holes--Bondo, fiberglass, whatever--but all I did with mine was to screw in the proper-size short stainless-steel sheetmetal screws till they were flush with the surface, before I repainted the area. (i.e. the screwheads are repainted the body color.) It's a bit of an industrial look, but so is the exposed piping, and it has the advantage of allowing the rocker panels to be quickly refitted if, say, a new buyer wanted them back on.
Porsche virgin 10-20-2006 08:38 AM
Very clever, Steve. Could you snap a pic for me one of these days?
Thanks.
Formerly Steve Wilkinson 10-20-2006 08:46 AM
A picture of a hole with a screw in it????? Ummm, it's raining mice and turtles right now, but if I get a minute later this weekend, I'll do it.
Porsche virgin 10-20-2006 08:58 AM
I understand the "screw-in-a-hole" concept, I was more interested in what the finished project looked like. Besides, I like looking at pictures.
Oh, and there is no rush with a picture. I know it is pouring today. (I'm at work in NYC right now.) I was thinking of this as a winter project.
Thanks.
jwetering 10-20-2006 07:34 PM
It's nice and sunny here this weekend so I will try to remember to snap a few pics tomorrow.
jwetering 10-22-2006 10:21 AM
It ain't all that pretty up close, especially since the car has been painted at least once without the rockers having been removed. Your car will undoubtably look better. Note I also removed the plastic plugs which covered the big holes. The plan is to get newer cleaner plugs for these.You could paint over them. I took them out for weight savings ;) Here goes:
http://forums.pelicanparts.com/uploa...1161537454.jpg
http://forums.pelicanparts.com/uploa...1161537554.jpg
http://forums.pelicanparts.com/uploa...1161537581.jpg
http://forums.pelicanparts.com/uploa...1161537622.jpg
http://forums.pelicanparts.com/uploa...1161537652.jpg
http://forums.pelicanparts.com/uploa...1161537680.jpg
Formerly Steve Wilkinson 10-22-2006 11:28 AM
Bill Verburg, you're of course right about the "least effective" weight being in the middle of the car, but I've already done the bumpers, muffler and a dozen other relatively major things. And 20 pound is 20 pounds less to carry.
Porsche virgin 10-22-2006 05:18 PM
jwetering, Thanks very much. I appreciate the pics.
BTW, what tires/wheels do you have back there? They look huge!
jwetering 10-22-2006 05:31 PM
9x16 on the back with 245/45 and 951 offset 8x16 on the front with 205/55.
Hard to find but worth the $ and effort. The best ******* setup there is for a 911 IMO. :D
BTW - there should be six pics in all, but everytime I load this thread I only see four or five, and different ones each time.
SmileWavy
dfink 10-22-2006 06:07 PM
Just had mine off to do torsions and thought I would like the look but it looks better on. If you have A/C you not only have the oil lines on the right but the A/C lines on the left. Also the way the front valance hangs down, the flow on the side of the car is just not right. Makes the car look like it is sitting higher than it is because the front and rear are sitting lower than the middle. If doing bumper replacement and A/C removal then it would look good.
Also the rubber was not to hard to put back on. Just put it on the front and slide it by hand toward the back. About half way this gets difficult so I released a few inches of the top of the rubber at the back edge and pulled on that as I pushed from the front and it went right on. Easy to put the top back in once it is in place. I never realized how flexible the rubber strip is till I took it off. Removal was real easy just peel it off.
Picture of mine with it off. The car is rolling slightly but you can see the front bumper is lower than the middle.
http://forums.pelicanparts.com/uploa...1160447486.jpg
jwetering 10-22-2006 06:26 PM
Here's one that really shows off the rear wheels.
http://forums.pelicanparts.com/uploa...1161566692.jpg
I do agree with dfink that the front valence, and rear side pieces don't line up very well without the rockers. And an interesting point thatthe car looks to ride higher visually, I've noticed this with mine but never connected the two dots. My solution ultimately is to replace th ebumpers, in the meantime, perhaps I should lower it some more ?!
