Porsche virgin's Avatar
Quick "can I remove this" question
Ya' know the lower valence between the wheels on '74-'89 911s with the rubber strip? Such as in this car?
Is there any reason I can't/shouldn't remove it? I guess it protects the oil lines, but I prefer this look:
TIA
'08 RX350 (Hers)
'84 911 Carrera
'83 911SC Cabrio
'06 Miata
Old 10-18-2006, 01:59 PM
Senior Member
Superman's Avatar
I prefer that look also, and my rocker panels are leaning against the wall of my garage. I don't believe they do much of anything to protect the oil lines. From a side-impact maybe. Pretty questionable. I say they are purely cosmetic. And ugly. I would also say that there are a few screw holes that should be plugged and sealed against the weather once you remove the rocker panels. I think those screw holes penetrate the side-tunnels.
Mocha 1978 911SC. "Coco"
Old 10-18-2006, 02:05 PM
Bill Verburg's Avatar
If you remove them your aero #s will be worse
Bill Verburg
Old 10-18-2006, 02:11 PM
You can remove them, but there will be some filling and smoothing that needs to be done to get the car to look as smooth as the second photo. If you aren't concerned about that, then no problem.
Old 10-18-2006, 02:41 PM
lov2fly's Avatar
Car looks great as is! Get of the computer, drive and have fun.
Old 10-18-2006, 02:51 PM
randywebb's Avatar
To get a visual of why Bill makes that comment, take them off and go for a high speed drive in the rain. You'll see that air (and dirty water) flow _up_ the sides of the car.
But hey - it's a Porsche - why let form follow function?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-18-2006, 06:09 PM
I took mine off, and welded up the holes as part of my re-back-date project.
I like the look.
'69 911 Targa w/ 3.2
Old 10-18-2006, 06:17 PM
ianc's Avatar
Oil lines on the passenger side look pretty unsightly with them removed.
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 10-18-2006, 06:57 PM
oneblueyedog's Avatar
What about Carrera 2/4 side skirts?
78SC coupe, Silver Metallic
Old 10-18-2006, 07:19 PM
klaucke's Avatar
Agreed, but perhaps more important for the street, his oil temps will likely be better.
Old 10-18-2006, 08:10 PM
Bye, Bye.
Scooter's Avatar
Please, no.
Elvis has left the building.
Old 10-18-2006, 09:13 PM
Wow. I didn't think I'd get this many opinions! BTW, neither car is mine.
My car is mainly used for autox, occasional street use, and I hope to get more into DE next year (had my first taste last month).
The aero aspect isn't too much of a concern. It wouldn't matter at autox speeds, and I'm not going for time during DE events.
The reason I'd take it off is because I like the old, cleaner look.
That said, I'm lazy and not comfortable with the "patching" and "filing" work that would need to be done to make it look clean and smooth.
If I take them off, I suppose the black rubber strip would be hard to put back on, so there would be no going back.
'08 RX350 (Hers)
'84 911 Carrera
'83 911SC Cabrio
'06 Miata
Old 10-19-2006, 06:19 AM
If oil temp is the problem the solution is usually oil cooler upgrade.
Bill Verburg
Old 10-19-2006, 06:26 AM
Funny you mention this because I'm in the process of researching this very topic. I have the 28-row brass cooler. My thought is, if I upgrade to the late model cooler, I should get a fan at the same time. My big worry about overheating is sitting in traffic on a hot day, with no air passing over the cooler. I'm considering the entire Elephant big mouth cooler and fan upgrade.
'08 RX350 (Hers)
'84 911 Carrera
'83 911SC Cabrio
'06 Miata
Old 10-19-2006, 06:32 AM
That would be a nice upgrade.
Bill Verburg
Old 10-19-2006, 06:39 AM
Senior Member
Superman's Avatar
Glad you brought this up. In the olden days, when they made beautiful race cars, the sides of the cars had an airplane fuselage look. With the rockers removed, my car now has this look. Yes, they now know that the ideal shape for aerodynamic purposes is that of a friggin' BRICK. If the speed limit in my area were 160 mph, then I might consider driving a BRICK.
No the rubber part is not impossible or even difficult to reinstall. I like the look of the oil lines. Next step is to do something about the ugly bumpers.
My rear valence is also removed. I had it off, and could not think of a good reason why I would put it back on. Now, if it were a girl's car, that would be different.
Old 10-19-2006, 06:57 AM
No, thanks! Not on an open highway with my RA-1s!
Besides, my car is dirty as hell already. A little more wouldn't be noticed!
'08 RX350 (Hers)
'84 911 Carrera
'83 911SC Cabrio
'06 Miata
Old 10-19-2006, 07:04 AM
Air Medal or two
afterburn 549's Avatar
remove the rear seats and rockers you will loose 20 lbs !!!! ( according to my scale) and thats a good reason for a delete -if your are staying under 150 mph
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 10-19-2006, 07:22 AM
randywebb's Avatar
re lazy -- too bad you can't just paint it white or put some FG in there and paint that white
- you're really after the look, right? and at the lowest possible effort?
Old 10-19-2006, 12:53 PM
What's FG?
And yes, lowest possible effort is good, when it comes to cosmetic things. Mechanical stuff is different.
'08 RX350 (Hers)
'84 911 Carrera
'83 911SC Cabrio
'06 Miata
Old 10-19-2006, 01:04 PM
