-   -   How do I install this stud/bolt thing? (pic) (http://forums.pelicanparts.com/porsche-911-technical-forum/310771-how-do-i-install-stud-bolt-thing-pic.html)
Emission 10-20-2006 07:00 PM
I don't even know what it is called. All I know is that the short threaded end goes into the turbocharger, and the CAT flange fits over the other end and a copper nut holds the whole assembly together.
So, it is part of the exhaust.
To pull the old "studs" out I will use two nuts and back them out with a wrench.
When I put this back in, does it go hand tight? Do I put two nuts on it and crank it down? Do I put anti-seize on it (can anti-seize even handle the turbocharger temps)?
http://forums.pelicanparts.com/uploa...1161395905.jpg
yelcab1 10-20-2006 07:03 PM
Put two nuts on it, tighten one against the other, and then use that to bolt it in.
89turbocabmike 10-20-2006 07:25 PM
If it will thread in by hand until it bottoms out, great, there is no need to torque that stud down and will just make future removal that much tougher. I personally use loctite hi temp copper anti-seize (c5-A) which is good to 1800F. It helps to prevent some of the corrosion that makes these difficult to remove.
