Automotive Monomaniac
Emission's Avatar
How do I install this stud/bolt thing? (pic)
I don't even know what it is called. All I know is that the short threaded end goes into the turbocharger, and the CAT flange fits over the other end and a copper nut holds the whole assembly together.
So, it is part of the exhaust.
To pull the old "studs" out I will use two nuts and back them out with a wrench.
When I put this back in, does it go hand tight? Do I put two nuts on it and crank it down? Do I put anti-seize on it (can anti-seize even handle the turbocharger temps)?
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 10-20-2006, 07:00 PM
Put two nuts on it, tighten one against the other, and then use that to bolt it in.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-20-2006, 07:03 PM
89turbocabmike's Avatar
If it will thread in by hand until it bottoms out, great, there is no need to torque that stud down and will just make future removal that much tougher. I personally use loctite hi temp copper anti-seize (c5-A) which is good to 1800F. It helps to prevent some of the corrosion that makes these difficult to remove.
Old 10-20-2006, 07:25 PM
