126coupe's Avatar
Is 10-15 HP really worth $3,500.00?
I was planning on twin-plugging my 2.5L race motor.
After crunching the #'s I am looking at a $3,500.00 bill.
$2,500 Distrib., Machine work $300.00, 2-MSD's $460.00, 2 blaster coils $120.00, wires $300.00.
I think my $$ is better spent on tires, $600.00 a set, thats 6 sets!!!
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 10-19-2006, 08:53 AM
North Coast Cab's Avatar
No. If you have the right high compression engine, cam etc. to utilize the benefits of twin plugging you'd get a lot more than that. Also, there is some cost reduction whe you sell your old distributor, coil etc.
J
1985.5 944 GTS
Old 10-19-2006, 09:02 AM
user & abuser
that is of course unless by twin plugging you prevent knocking, or many other possible faliures.
don't look at twin plugging as a performance gain, as it offers very little in that regard (does allow high comp and larger bore..) but it is capable of making a more consistent and reliable burn.
its insurance and peace of mind... along with the coolness of having the same # of spark plugs as a v-12 :P
one other note, i'm not sure if this is related, but because of the increased burn effienceny my physics skills tell me that the temperature loading should be less...... could be wrong though... never really hit any practical applications.
vini vidi vici
Old 10-19-2006, 09:03 AM
Unregistered
sammyg2's Avatar
I am amazed at how much some folks pay for a few more HP out of their 911s. Even SSIs and muff cost at least $100 per HP increase.
I'm a cheap SOB so I prefer to just pressurize the intake and pay around $15 per HP.
Old 10-19-2006, 11:46 AM
randywebb's Avatar
Where did the $2,500 Distrib. come from ???
You have to decide if the insurance and smoother running + a bit of hp is worth it to you.
If you have the motor apart, then defintiely get it bored for twin-plugs now. You can add (or not add) the other items later.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-19-2006, 12:45 PM
126coupe's Avatar
Well I went for twin-plugging. JB Racing out of florida makes some very nice quality stuff. Off to the machine shop!
28' Pace Trailer
Old 10-20-2006, 09:31 AM
126coupe's Avatar
The distrib.
28' Pace Trailer
Old 10-20-2006, 09:32 AM
126coupe's Avatar
Rennsport Systems out of Oregon
28' Pace Trailer
Old 10-20-2006, 09:36 AM
Warren Hall Student
Bobboloo's Avatar
You can get 10-30HP at the track for less than $100.
Water vapor cooled 911 - the Rubbermaid Solution
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 10-20-2006, 10:10 AM
user & abuser
twin plugging is not only neat/fancy, safe but if orignally planned i believe it allows for more power to be made.
i am running 100mm pistons with more then 11:1 cr.... try doing that without twin plugging... would be a mess real fast.
w/o twin plugs your limited to around 97mm bore and defiently no more then 10.3:1....combine those differances, 3mm bore and .8 cr+... and you have more then 15-20hp on the table.
add that in with saftey and the bragging rights..
vini vidi vici
Old 10-20-2006, 11:15 AM
randywebb's Avatar
Well, a few years ago I went with the dual drive 964 type dist. with SC inards. I think I paid about &800 and $60 respectively for the used parts. I forget the cost for a guy to put it all together but it was < $1,000 total I'm sure.
OTOH, it is heavier, can have belt failure, and just looks like a kludge compared to a true 12 output dist.
Maybe the 12 dist.s are cheaper now with the Burn bros. caps avaialble??
Old 10-20-2006, 12:49 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
While the cost is indeed expensive, the benefits are there (power, fuel economy, reliability)...
In your dedicated track only car, that 10-15 horsepower may be the difference in finishing 1st or being the 1st loser...
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 10-20-2006, 03:06 PM
126coupe's Avatar
Ralph
Well I got the price down to $2,600.00 Thats everthing I need. With a little more aggressive cam (fom GE60 to an 80)
a bump in CR from 10.1:1 to 10.5:1, the twin-plugging I believe I will feel the difference, not to mention how cool the big Distributor will look.
28' Pace Trailer
Old 10-20-2006, 04:07 PM
Air Medal or two
afterburn 549's Avatar
m.o. why not go stand alone so you have options later...your not far off $ wise and is more flexible
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 10-20-2006, 05:06 PM
Wer bremst verliert
JohnJL's Avatar
There are other twin-plugging alternatives for much less...www.msefi.com
There are some here running EDIS twin plugs off Megasquirt 2 for $500 including machinework and have a fully programmable ignition curve to boot. You don't need to use the EFI components if you don't want but they'll always be there when you want them...
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-20-2006, 05:20 PM
Air Medal or two
and you dont have a hvy thing ( dizzy ) hanging out the back of the car..
Old 10-20-2006, 05:38 PM
efhughes3's Avatar
The sick thing is, if we had American iron, we could get a nice crate MOTOR for that kind of money. But then again, they need to spend money on chassis, brakes and such to try and get on par with us.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 10-20-2006, 05:49 PM
Zeke's Avatar
Mark, are you kidding? There are lots of guys out there that will do anything with any kind of money to be a half a car ahead at the end of the straight. Every lap. If 15 HP don't do it, then you'll have to spend another wad for 10 more, and so on. Or, you're not a racer.
Now, I read Grady's thread on the water injection. I've heard good things about water injection all my racing and automotive life, in general. Why aren't there bolt-on systems available like all this NOX stuff?
Mark, you could have the extra from both and the second one be a lot cheeepa. Put a '72 type oil tank in front of the regular one. Oh, wait, your oil tank is this silo that sits in the pass side. In that case, use a regular oil tank for your water. A '69-'71 cold start spray bar is all you need to aim that water down the 6 throats.
Old 10-20-2006, 05:52 PM
Air Medal or two
we are all sick anyway LOL
Old 10-20-2006, 06:47 PM
gumba's Avatar
while the 12 plug distributors are cool, I would think you would have better control over setting up the timing with an Electromotive system or something similar. My old Electromotive HPV-1 lets you set up the timing at idle, 3K & 8K with a rev limiter.
3.4 twin plug, Electromotive, 46mm webers for the race car
3.5 twin plug (Bosch 12 plug dis) turbo for the street car
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 10-20-2006, 07:41 PM
