holtjv's Avatar
Ha! Just re-read your first post:
"Nothing major, I'm really doing it just for fun. I'll add a sound pad, replace hoses and clamps, adjust the valves and do some cleaning."
Warren Hall (Early S Man), 1950 - 2008
2006 Tri D675 Scorched Yellow
2006 Ducati Sport Classic mono SOLD
1979 SCWDP #0020 Talbot Yellow SOLD
Old 01-03-2007, 11:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #181 (permalink)
Dan in Pasadena's Avatar
Glenn, Congrats for hanging in and finishing it nicely.
The color in your engine bay is Sahara Beige or very close to it; same color as my car. By any chance did you find a rattle can with the color you used? Because if you did I'd love to know the brand and color name...I want to do mine and that looks very close. If not, did you get some paint mixed up by an automotive paint shop? Use a Preval or a regular spray gun? Some details, please?
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 01-03-2007, 01:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #182 (permalink)
Tired Member
DaddyGlenn's Avatar
Everyone, thanks again for the help and support. I did go into this as a wide-eyed optimist. But I am happy with where I ended up. I had/have to fix a few things I hadn't planned on but better to know about it now instead of being surprised later.
Terrible - the clutch is great. Between the new clutch/flywheel and fresh fluid in the tranny, shifting is a whole new (and faster) experience.
Dan - I used a rattle can for the engine bay. It was Dutch Boy acrylic "yellow" that I found at Sears. Wish I knew what a real Talbot yellow looked like.
This weekend I will re-torque the CV bolts and go over everything looking for loose bits and small leaks.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 01-03-2007, 01:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #183 (permalink)
Glenn, Thanks VERY much for the rattle can info. I'll be at Sears after work to get one...try it out on my new Halon fire extinguisher. Per your PM, here are a few pix of my car. As I said, Sahara Beige doesn't photograph accurately. It isn't quite as hot as the first picture, but definitely not as soft as the other two. Real life its a little stronger than that. The last two pix are of Adam Chaplin's beautiful Talbot car from down Under. My car is a '76 but I backdated it with narrow bumperettes, metal grill (like Adam's), fog delete, bright mirror and 15x6's. I've got more pix if ou need them. Best, Dan
Dan in Pasadena
Old 01-04-2007, 08:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #184 (permalink)
Tired Member
DaddyGlenn's Avatar
Thanks Dan! Beautiful car(s).
I'll have to take my car to a PCA event to do a side by side comparison.
According to Porsche N.A., my car was delivered in Talbot Yellow. However, the rocker panels and front (for the lack of a better word) chin piece do not appear to have been repainted like the rest of the car. Those parts are a lighter yellow, closer to the color of your car.
To add to the confusion, in a few spots where the paint has worn to the metal and in the areas under the trunk carpet as well as under the car near the transmission it looks like the base coat of paint is a very bright color similar to Rally Yellow.
Perhaps my car was stripped and color changed at some point in its life then later changed back poorly.
Glenn
Old 01-04-2007, 08:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #185 (permalink)
Tired Member
DaddyGlenn's Avatar
Well, it has been a little more than a year since the engine went back in and since then I have added an additional 10-12,000 miles and run seven autocrosses during that time.
As of this afternoon, the engine is out again. It only took me about 2 1/2 to 3 hours this time, again without help.
If I can find our camera, I'll post a picture of what a year's worth of daily driving has done to the appearance of the engine.
My biggest concern was how much has the pitting on the cam has grown. I have yet to compare last year's picture (posted earlier in this thread) to the cam now but after an initial glance at the cam I'm thinking there has been very little change, if any. I'll give it a very close comparison sometime in the next day or two.
If it hasn't grown and no new pitted areas have shown up, I'll leave the 964 cam upgrade for another year. This engine drop will then be for a valve adjustment, new CV joints, rear wheel bearings and perhaps some suspension work.
Glenn
Old 01-13-2008, 06:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #186 (permalink)
SP2 SP2 is offline
SP2's Avatar
Sounds like you have had a lot of fun in the last year.
Sorry to hear about the pitting. Good oil is the only thing you can do to slow it down. What oil do you use?
Thanks for the update!
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 01-13-2008, 06:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #187 (permalink)
Tired Member
DaddyGlenn's Avatar
Thank you. I use Valvoline VR-1 20w-50. Changed every 3,000 miles.
Glenn
Old 01-13-2008, 06:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #188 (permalink)
SP2 SP2 is offline
SP2's Avatar
That's what I use too. I have 964 cams in my SC too. I had them ground and I installed them last year.
James
1981 911SC Wine Red
Old 01-14-2008, 07:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #189 (permalink)
Tired Member
DaddyGlenn's Avatar
Is there a big difference with the 964s?
Glenn
Old 01-14-2008, 07:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #190 (permalink)
dshepp806's Avatar
Very inspiring thread..
Best,
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 01-15-2008, 02:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #191 (permalink)
Tired Member
DaddyGlenn's Avatar
I had a chance to compare the pitted cam lobe to the picture I took last year. I blew up the picture and checked each and every nook and cranny, relative size and shape every comparison I could come up with and I cannot find any change at all.
So, with crossed fingers, I will move on to examining all the other lobes.
Glenn
Old 01-15-2008, 06:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #192 (permalink)
Kaliv's Avatar
Hey Glenn,
I've been putting off this type of project for a while...but I need to do an engine drop and replace a few broken studs. I see you started in Oct 21 and ended Jan 2. To me, that sounds like a long time to be out of your car...and with my vastly lacking experience, I'd probably be out longer doing it all myself.
My question is: How many man-hours do you think it took you from start to finish - engine drop to engine install?
-= Kaliv Farstryder =-
'87 Porsche 911
Old 01-15-2008, 06:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #193 (permalink)
Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
subscribing, some great info and pics here -- thanks.
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 01-15-2008, 08:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #194 (permalink)
Tired Member
DaddyGlenn's Avatar
Originally Posted by Kaliv View Post
Hey Glenn,
The first drop that started this thread, took maybe six hours. But I was going very slowly. The second one I just did was 2 1/2 hours. I'd add an hour on the install.
You might want to see if there is a local Pelican with experience that could help you.
The Oct-Jan time frame was due mostly to finding extra stuff to do while I was in there and my way too busy schedule. If my weekends had been free and I had all the parts up front, I would have been done in a couple weekends.
Glenn
Old 01-16-2008, 03:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #195 (permalink)
Greetings!
Dear DaddyGlenn, you are one hot daddy! And your wheels aren't bad either! Thanks for sharing all your excellent knowledge and experience!
Three women were talking about their love lives.
The first said, "My husband is like a Rolls-Royce; smooth and sophisticated."
The second said, "Mine is like a Porsche; fast and powerful."
The third said, "Mine is like an old Chevy. It needs a hand start and I have to jump on while it's still going."
Old 01-27-2008, 05:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #196 (permalink)
Hey Kaliv
Kaliv
I did my engine drop and rebuild and reinstall in 4 days. 8 hours a day.....of course that covered setbacks of missing parts from the gasket set.
It takes about 2 to 3 hours your first time to drop the motor. Your 2nd and on takes less time because you will actually know what you are looking for.
the install will take longer, especially if you are doing it yourself. But goes rather quick if you have 2 people who are doing it, especially if they have done it before.
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 01-27-2008, 09:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #197 (permalink)
Tired Member
DaddyGlenn's Avatar
I typically take my time, spending too much time admiring the engineering beauty and thinking about how everything works. But, I think I will see how fast I can do the install all by myself.
That is when I get all the other stuff done and have a some time. (I'm toying with refreshing the rear suspension "while I'm in there")
Glenn
Old 02-05-2008, 07:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #198 (permalink)
