Tired Member
I bagged the hoses, the electric panel and the A/C compressor. then I broke out the degreaser, scrub brushes and the pressure washer.
A few hours later... I have a dilemma. I have suspected that my "Talbot Yellow" car has at some point in its life been color changed to a different yellow. I'm thinking "Speed Yellow." Some have told me that the color of my car is "Talbot Yellow." however I have seen a few pictures of Talbot Yellow cars that are a lighter, more pale yellow. There are also a few body panels that appear to be lighter/more pale than the rest of the car. If you look in the first and second picture you will see that the yellow that was under the sound pad is indeed a lighter and more pale color. The color paint I have purchased is closer to the lighter color that the darker yellow on the rest of the car and the rest of the engine bay. I had always thought that I would do a windows out re-paint some day and make sure the car ended up the "Talbot Yellow" it should be. Also, as you can see, the paint in the engine bay isn't that bad. So the question is.... should I repaint the engine bay the lighter color or leave well enough alone until I get around to the total re-paint?
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
Tired Member
T'was a silly question. Of course I painted it. Here are the after pictures.
I also found time to complete the last few items on the engine. With the exception of replacing one of the connectors on the back up switch wire, it is ready to be reinstalled. Other remaining tasks include: install sound pad reinstall electric panel rebuild CV joints then install engine and drive.
Dixie Region R Gruppe
Glenn,
Wow, that thing is really coming together for you, I for one don't know if i could wait that long to drive , but you are sure making it worth the time down. Nice job. Phil
Instagram @phillipkj4 1980 911 SC Backdated Viper Green 1992 Ferrari 348TB |
Tired Member
Anybody know what these are for?
Glenn hows it going taking time off for Christmas or have you got it back up and running?
1997 328i convertible 1998 528I |
Tired Member
I'm making good progress. I've disassembled and rebuilt two CV joints and I installed the sound pad yesterday. All that is left is to do is the other two CVs and clean the air filter. Then the engine goes back in. I don't go back to work until next Wednesday so getting it running by then shouldn't be a problem. I'll post pictures in a couple of days.
Glenn,
I think they are the mounting holes for the vacuum chamber on a sporto Cheers Ray |
Glenn: now you've got me wondering about my talbot yellow--I can tell it's been resprayed in about 5 or 6 different places but the color is definitely not pale--but not as intense as speed yellow, by any means.
That fan shround looks brighter than any paint on your car I've seen--just the photo? Jack PS. You started out inspiring me to drop my engine but I am horrible about the 'while you're there' situation--so I don't want to get started...!
Warren Hall (Early S Man), 1950 - 2008 ------------------------------------ 2006 Tri D675 Scorched Yellow 2006 Ducati Sport Classic mono SOLD 1979 SCWDP #0020 Talbot Yellow SOLD |
Tired Member
Thanks Ray. Others have agreed with you. They are mounting holes for the sportmatic vacuum system.
Jack - the color I ended up using in the engine bay is too light and my car isn't quite Speed Yellow but I'm fairly certain the respray was not a good color match to the correct Talbot Yellow. The fan is "Safety Yellow." Out of laziness, I went with an easy and obnoxious color instead of trying to get a correct match. If I ever get around to a windows-out repaint, I'll match all the colors correctly at that time. Glenn
Tired Member
Happy new year to all. I hope you rang in the new year with more excitement than I did. I completed the rebuild of the CV joints last night and got one shaft back on the car.
My 10 year old son and I re-installed the engine a couple days ago and have slowly been reconnecting the various wires, cables and oil lines. The CV joints are not long for this world but I should be able to get a few more miles out of them before they will need replacement. I found spots like this on three of the four joints. And the fourth wasn't much better. Here is a shot of the bearings from the joints. The one on the left is clean. You can see the chunks of what used to be the CV grease that I picked out of the joint. I should have the other shaft installed today then I think I will be ready to fire her up. I wonder what I forgot.........
Tired Member
The second drive shaft is in. All lines, wires etc have been checked and double checked. Cranked the engine without starting just enough to build up the oil pressure. Ran the fuel pump long enough to clear the air from the lines and verify I had no leaks. Then with a couple of back fires and a belch of smoke she started. Wooo Hooo!!
The smoke continued as trapped cleaner and residual oil burned off but ... the alternator light did not go out. So I shut it down, knowing that tomorrow I will be opening things up a bit to move a couple of wires on the alternator. Damn! That is a lot of work for a stupid mistake. I'll also be double checking the shifter adjustment, throttle adjustment and resetting the clock (very important). The light at the end of the tunnel is very bright.
Glenn sorry to here about the alt hook ups. Hope you do not have to go into it to far to get it worked out. Good luck. Make sure you post pics when you are done.
Tired Member
I'm Done!!!!!
Really, there is nothing left to do on this project. The engine is in and runs great. Thanks to a new clutch kit and cleaning up the clutch throw out mechanism, it feels like new. It will take me a day or two to get used to that. I must sincerely thank everyone who provided knowledge, tricks, tips and kind words. Your support has been tremendous. I never felt alone. Here is a shot of the finished product. I will start to put together a "lessons learned" essay to post under another heading. But that may take a few days....I have some catching up to do.
Glenn,
I have not posted on your thread in a while. It looks great!!!! Good luck with the next project. Dave
Gemini Blue 73.5 911 T Sold 1994 C4 Widebody Sold |
Glenn, that engine looks tight! Great job!
James 1969 911E Slate Grey 1981 911SC Wine Red 1997 911C4S Ocean Blue |
19 years and 17k posts...
Glenn,
Excellent work, thanks for documenting the process. Have fun!!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Glenn, Looks great. I hope the cam wear is not an issue for a long time. But drive it hard until then. I will be in touch after a while to see how the clutch is working for you when I replace mine I would like to go the route you went. Anyway Good Luck and have fun!
i have not read this thread, so if someone has told you this, here it is agian. keep an eye on your CV joint bolts, put in new washers and recheck after 100 miles or so. you might want to put some locktite on them too. check the length of the bolts and make sure a thread or 2 is past the mounting flange. if you need longer screws, check with fastenal, i just bought a bag of 50 for $10.
car looks good! nice job!
Congrats, Glenn--looks awesome, I, too, am going to be tackling the clutch in a few months and have already learned a lot from your thread.
And your color looks exactly like mine--only a bit nicer. Good job--bet you're glad to be back behind the wheel--certainly look happy enough! Jack
