Banned
Porsche squeaks when turning
HI I have a 1982 porsche 911 sc, most of the time I get this annoying squeaking sound when I turn right, but once I stop and go staright it goes away. Any suggestion on where I should start looking? Thanks
Old 10-21-2006, 04:34 PM
Southern Class & Sass
Dixie's Avatar
bearings
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 10-21-2006, 05:43 PM
mca mca is offline
mca's Avatar
i had same problem ... bearings
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 10-21-2006, 05:49 PM
I thought bearings went clunk clunk clunk?
Old 10-21-2006, 06:17 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
nope, that's a broken swaybar mount, or cv joint bearings
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 10-21-2006, 07:30 PM
cantdrv55's Avatar
OK, for those of us less knowledgeable about cars, which bearings are we talking about? Wheel bearings? Are those the ones that require repacking every so often?
Old 10-21-2006, 07:54 PM
rteague's Avatar
replace wheel bearings when you can afford to. Packing just prolongs problem. What you hear are the brake pads rubbing the rotors because loose bearings allow rotor to lean.
84 m491 blk/blk coupe
1st Place The Ventura Show
September 9 2006
Last Place The Ventura Show
September 10 2006
Old 10-21-2006, 08:26 PM
UFLYICU
ZOA NOM's Avatar
Interesting, I had always thought the bearings began to howl because they would vibrate at an audible frequency when loose.
Replacing the wheel bearings should be accompanied by replacing the races those bearings will ride on as well, as they are most likely scored.
prc-racing.com
Old 10-21-2006, 08:32 PM
rteague's Avatar
When going around corners, if it sounds like squeaking brakes, can be bearings can be pistons in calipers not retracting due to swolen brake lines or caliper problems. definitely howling is bearings or me everytime I have to pay for my porsche habit. Where did you get avatar? Hard to get away from your post.
September 9 2006
September 10 2006
Old 10-22-2006, 10:57 AM
930turbo's Avatar
If the squeak follows the steering input directly, check the ball joint. The one on the right usually fails first on high-mileage cars. The right tire is more subject to pot-holes in the road. The joints have a tendency to squeak when rotating with the steering input just prior to pulling through. If this happens, the bottom of the strut and front wheel heads for the back and takes several expensive items along for the ride. Not to mention complete loss of control. This can ruin your entire day.
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 10-22-2006, 12:47 PM
Tom '74 911's Avatar
You could also check your sway bar bushings. Mine start squeeking now and then - although not limited to turns only. Spray a little silicone in there - cheap fix. Can't hurt to check?
Squeeks are no fun to chase! Good luck.
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 10-22-2006, 06:21 PM
UFLYICU
ZOA NOM's Avatar
Homemade
prc-racing.com
Old 10-22-2006, 06:38 PM
rteague's Avatar
ok now everone is jealous!
September 9 2006
September 10 2006
Old 10-23-2006, 10:01 AM
A short thread by most counts, but I printed it out for my file.
It's packed with goodness.
Old 10-23-2006, 11:51 AM
