Need Help, A/C Thermostat Control
My probe that goes in to the condenser broke. I need to find the whole switch from the control all the way to the probe at the codenser. Part # 911 613 121 00. Is this part hard to find? Is it expensive? Any tips on the installation?
Mike Miller 89 911 ------------------ |
Mike,
It sure looks like it will not be fun to install and the tube that goes to the "smugglers trunk" cannot be kinked or it will nt work right. Pls let us know how it goes... I may have to do one as well! JA |
Does anyone have anymore info on this old thread?
Wow that is the oldest post I have ever seen dug up.
I would suggest you contact Griffith's and see what his soultion is. http://www.griffiths.com/ |
pelican has the part $ 51.75 911-613-121-01-M145
Took me an about an hour to change out in my 77 930. |
I paid about $65 each locally for the TWO I bought. I broke the first one trying to get it to fit the console. We actually ordered several and they were all the same size requiring some modification to the console to make it fit. It works great now that it is in.
The original size switch - at least for a Carrera is NLA. The part that is currently available from our host will require some modification of the console to allow it to fit. I also tried sourcing a replacement part through several local Automotive AC suppliers but they could not find an equivalent in any of their parts catalogs. In the end I was able to refurb the switch by simply cleaning the contacts. If the capillary tube is broken or damaged though, that won't be an option.
Actual removal and replacement of the switch wasn't really that difficult just kind of tedious & a bit ergonomically challenging. Its probably easiest to remove the grommet from the firewall to thread the tube back through and reinsert the grommet/tube together than trying to thread it through with the grommet in place. |
Just did this a couple of weeks ago. Sterted with the part from our host, which would not fit in the consloe of my '88 without doing some cutting. Returned that and got one from Griffiths, which is smaller and will fit. It IS a major PIA to replace, but Griffiths provides great instructions..
| All times are GMT -8. The time now is 02:04 AM. |
