-   -   question: clutch slave rebuild, the circlip. (http://forums.pelicanparts.com/porsche-911-technical-forum/311313-question-clutch-slave-rebuild-circlip.html)
rnln 10-23-2006 10:43 PM
Has anyone rebuilt the clutch slave cylinder yourself?
I actually bought a new slave cylinder but found that the internal popped out (the circlip popped out after installed, while bleeding). I put everything back in and use a big socket to bang the circlip in place but it popped again after installed/bled.
My friend said that once it's popped, I will need to buy a whole new slave because I can never make the circlip tight. Is he right? It will be sad if I have to shell out the $$ on another new slave without knowing if the circlip will stay.
To me, I think there must be a way to tighten the circlip since it is designed that way. Does anyone actually did it? Can you share the technique?
Why the circlip popped?
rnln 10-24-2006 03:10 PM
anyone?
