rnln's Avatar
question: clutch slave rebuild, the circlip.
Has anyone rebuilt the clutch slave cylinder yourself?
I actually bought a new slave cylinder but found that the internal popped out (the circlip popped out after installed, while bleeding). I put everything back in and use a big socket to bang the circlip in place but it popped again after installed/bled.
My friend said that once it's popped, I will need to buy a whole new slave because I can never make the circlip tight. Is he right? It will be sad if I have to shell out the $$ on another new slave without knowing if the circlip will stay.
To me, I think there must be a way to tighten the circlip since it is designed that way. Does anyone actually did it? Can you share the technique?
Why the circlip popped?
Fat butt 911, 1987
Old 10-23-2006, 10:43 PM
rnln's Avatar
anyone?
Fat butt 911, 1987
Old 10-24-2006, 03:10 PM
