SCWDP911's Avatar
door pocket carpet question
I am pretty sure I am getting ready to change my carpet to black. I am leaving my door panels grey-beige, but I want the pockets to be black. Question is, has anybody reading this ever replaced the carpet on the pocket with new? Is it difficult enough to warrant trying to find a nice set of used black ones instead?
Shane
- 1984 928S
Old 12-30-2009, 01:45 PM
CT944's Avatar
How about a set of brand new (aftermarket) black panel carpet? I bought a kit and ended up not using them, as the stock ones were so nice.
Easy job.
$45 shipped.
Thanks.
2007 997 TT
1992 500e
Old 12-30-2009, 02:00 PM
SCWDP911's Avatar
Where are those from? I would want ot make sure the carpet matched...
Shane
- 1984 928S
Old 12-30-2009, 02:35 PM
Are you going to buy a carpet kit, if so it may have the carpet for the door pockets. My kit came with them and they were easy to glue on.
PorschePilot
74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration
MID9 Member
Beechcraft V-Tail Bonanza
(Fly'n high and low)
Old 12-30-2009, 02:44 PM
SCWDP911's Avatar
OK, sounds like they are easy to install then. I was not sure if they came as part of the standard carpet kit or not. Sounds like maybe they do.
Shane
- 1984 928S
Old 12-30-2009, 02:47 PM
CT944's Avatar
From a carpet kit I bought. I paid extra to get all carpeted surfaces including the trunk lining.
2007 997 TT
1992 500e
Old 12-30-2009, 02:53 PM
SCWDP911's Avatar
I meant what company, and which carpet from which company...
Shane
- 1984 928S
Old 12-30-2009, 02:56 PM
CT944's Avatar
I can't remember off hand, but it is domestic acrylic plush-cut pile.
2007 997 TT
1992 500e
Old 12-30-2009, 03:03 PM
Shane
If you change out the carpets use the Silverknit, it is the product Porsche used.
To cover the map pockets, you will need solid map pockets, a can of 3M super trim adhesive spray and a stapler. The vinyl edging needs to be stapled on the inside top of the pocket edge, otherwise the vinyl will peel back on a hot day due to the porous nature of the map pocket lining.
Old 12-30-2009, 08:48 PM
Almost Banned Once
sc_rufctr's Avatar
Originally Posted by Vmarch View Post
Shane
x2... Good advice.
It's not as hard as you might imagine. Just takes your time and be methodical.
Believe me if I can do it so can you.
- Peter
Old 12-30-2009, 09:04 PM
