-   -   3.2 Header Size (http://forums.pelicanparts.com/porsche-911-technical-forum/311582-3-2-header-size.html)
North Coast Cab 10-25-2006 02:10 PM
3.2 Header Size
I'm finding conflicting information on the best header size for a 3.2. Basically stock other than the exhaust and chip.
Does anyone know the size of SSI's or '74 and earlier HE's?
1 1/2, 1 5/8 or 1 3/4?
Race car application.
TIA, John
Jeff 10-25-2006 02:33 PM
For track applications on a 3.2 you should use 1 3/4 headers.
Got the strut brace. Thanks.
Bill Verburg 10-25-2006 02:39 PM
SSI primaries are 35mm(1 3/8")ID, for street use you would want ~42mm(1 1/2")ID, for a full race motor ~44.5mm(1 3/4") ID
pmajka 12-28-2006 09:59 AM
Does SSI have a website, i would like to know how Much 1 3/4s heat exchangers would cost????
The Chef 12-28-2006 05:31 PM
Sold by our host. I think they have specs.
pmajka 12-28-2006 05:32 PM
Yes, but looking for more specs. maybe some photos.
gumba 12-28-2006 06:15 PM
According to Richard at PMO the header size is based on whether your using a muffler or straight pipes. On my 3.4 race motor using 50mm PMO's he suggested a 1 5/8" with a muffler and a 1 3/4 - 1 7/8" with straight pipes.
You should consider using the 993 heat exchangers instead of the SSI's, if you want heat in the race car. Tyson has a post discussing the advantages.
JeremyD 12-28-2006 06:27 PM
Primary tube size
SSI 38mm OD/ 35mm ID
GHL 41mm OD/ 38mm ID
B&B 41mm OD/ 38mm ID (small tube)
B&B (964 version) 44.5mm OD /41mm ID (large tube) too big for a street 3.2
SC/RS 42mm ID
pmajka 12-28-2006 06:36 PM
Ah, this is useful!
for those who dont know, I have an Andial 3.7L motor.
I think ( but am not sure) i have stock 3.2 exhaust? (just a little pinch)
So, i was looking at either BB 964 or 993 HEs.
But dont the 993s have the exhaust studs rotated 90degrees?
Was the stock Carrera 3.2 and the stock 964 exhaust the same?
JeremyD 12-28-2006 06:39 PM
Originally posted by pmajka
Ah, this is useful!
Yes, the 993 HE - if you want to use on either a 964 or 3.2/3.4/3.7 need to have the flanges rotated on one side of the engine.
I am actually thinking of selling my 964 B & B heat exchangers and MK muffler -
pmajka 12-28-2006 06:58 PM
Hmmmm....contact me offline.
pmajka AT shiraz.dynip.com
84Euro 12-28-2006 08:45 PM
JermyD, I sent you a PM
sus911 12-28-2006 09:21 PM
here's what Ben (M&K) is doing for me.
993 HE's flipped, 2/1 s/s muffler:
http://forums.pelicanparts.com/uploa...1167369655.jpg http://forums.pelicanparts.com/uploa...1167369679.jpg
JeremyD 12-29-2006 06:27 AM
Here are the 964 B & B headers
http://forums.pelicanparts.com/uploa...1167401984.jpg
http://forums.pelicanparts.com/uploa...1167402360.jpg
