North Coast Cab's Avatar
3.2 Header Size
I'm finding conflicting information on the best header size for a 3.2. Basically stock other than the exhaust and chip.
Does anyone know the size of SSI's or '74 and earlier HE's?
1 1/2, 1 5/8 or 1 3/4?
Race car application.
TIA, John
1985.5 944 GTS
Old 10-25-2006, 02:10 PM
GFCC
Jeff's Avatar
For track applications on a 3.2 you should use 1 3/4 headers.
Got the strut brace. Thanks.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 10-25-2006, 02:33 PM
Bill Verburg's Avatar
SSI primaries are 35mm(1 3/8")ID, for street use you would want ~42mm(1 1/2")ID, for a full race motor ~44.5mm(1 3/4") ID
Bill Verburg
Old 10-25-2006, 02:39 PM
pmajka's Avatar
Does SSI have a website, i would like to know how Much 1 3/4s heat exchangers would cost????
Have you ever felt suffocated while watching the Oxygen Channel?
People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself.
88 Carrera
Old 12-28-2006, 09:59 AM
The Chef
Guest
Posts: n/a
Sold by our host. I think they have specs.
Old 12-28-2006, 05:31 PM
pmajka's Avatar
Yes, but looking for more specs. maybe some photos.
88 Carrera
Old 12-28-2006, 05:32 PM
gumba's Avatar
According to Richard at PMO the header size is based on whether your using a muffler or straight pipes. On my 3.4 race motor using 50mm PMO's he suggested a 1 5/8" with a muffler and a 1 3/4 - 1 7/8" with straight pipes.
You should consider using the 993 heat exchangers instead of the SSI's, if you want heat in the race car. Tyson has a post discussing the advantages.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 12-28-2006, 06:15 PM
MBruns for President
JeremyD's Avatar
Primary tube size
SSI 38mm OD/ 35mm ID
GHL 41mm OD/ 38mm ID
B&B 41mm OD/ 38mm ID (small tube)
B&B (964 version) 44.5mm OD /41mm ID (large tube) too big for a street 3.2
SC/RS 42mm ID
Old 12-28-2006, 06:27 PM
pmajka's Avatar
Ah, this is useful!
for those who dont know, I have an Andial 3.7L motor.
I think ( but am not sure) i have stock 3.2 exhaust? (just a little pinch)
So, i was looking at either BB 964 or 993 HEs.
But dont the 993s have the exhaust studs rotated 90degrees?
Was the stock Carrera 3.2 and the stock 964 exhaust the same?
88 Carrera
Old 12-28-2006, 06:36 PM
JeremyD's Avatar
Originally posted by pmajka
Ah, this is useful!
Yes, the 993 HE - if you want to use on either a 964 or 3.2/3.4/3.7 need to have the flanges rotated on one side of the engine.
I am actually thinking of selling my 964 B & B heat exchangers and MK muffler -
Old 12-28-2006, 06:39 PM
pmajka's Avatar
Hmmmm....contact me offline.
pmajka AT shiraz.dynip.com
88 Carrera
Old 12-28-2006, 06:58 PM
JermyD, I sent you a PM
84 911 Euro
3.6 liter
Old 12-28-2006, 08:45 PM
here's what Ben (M&K) is doing for me.
993 HE's flipped, 2/1 s/s muffler:
cheers,
Phil
84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies.
Old 12-28-2006, 09:21 PM
JeremyD's Avatar
Here are the 964 B & B headers
Old 12-29-2006, 06:27 AM
