Scott R's Avatar
How to roll power windows up with the engine out
Did something stupid when I pulled my engine for rebuild and left the power windows down. It's going to be quite some time before the engine is back in. Is there anyway I can get power to the window motors to get the windows up? It's in my garage but still not entirely secure from the elements.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-28-2006, 09:56 AM
Make sure the starter cable isn't touching anything and hook up the battery?
Old 10-28-2006, 10:06 AM
Scott R's Avatar
I tried that in fact, seems like the fuse bank is not getting power, maybe I need another ground.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-28-2006, 10:10 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
Just run a jumper wire between the positive battery terminal and the fuse for the window relay.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 10-28-2006, 10:18 AM
Scott R's Avatar
Ok, going to try that, thanks.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-28-2006, 10:19 AM
audi2.7t's Avatar
On the carrera you can remove the smaller door speaker and crank up by hand (with socket)... dunno about the SC if you dont have the small upper speaker.
'96 Dodge Viper
'09 Maxima
'05 zx10..(0-100-0 before your turbo even spools!!)
'99 Rottweiler
'08 Cane Corso
Old 10-28-2006, 11:05 AM
one of gods prototypes
bell's Avatar
pull the switches in the driver door and use a 12v cordeless drill battery to power up the motor if all else fails.
Brought to you by Carl's Jr.
Old 10-28-2006, 03:22 PM
mark_d_mcguire's Avatar
Yes, do it from the switches. You can hotwire straight to a battery if you have a wiring diagram
Mark
H Class Race Car Project
Old flames: 1999 C2 Race Car #78; 1983 SC Race Car; #78; 1990 C2; 1978 SC Race Car #78; 1988 Carrera; 1977 911S
Old 10-29-2006, 07:15 AM
I'd start to worry about that.
Old 10-29-2006, 08:29 AM
