Nine9six's Avatar
Lightbulb Turn indicator question
I just noticed that my right turn indicator flasher blinks noticably quicker than my left. This has not always been the case, so I am wondering if this is indicative of soon to fail flasher?
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 10-29-2006, 08:28 AM
Goth's Avatar
Most common cause is one of the bulbs isn't working as designed (as in burned out bulb, bad connection, wrong wattage bulb). If all bulbs working and not changed since it was flashing correctly, I would then suspect the flasher.
Doug
84 Carrera Coupe - Black (the Goth look)
The more I learn, the more I realize I don't know
Old 10-29-2006, 09:09 AM
DW SD's Avatar
Goth is spot on.
Look for a blown bulb or one that is not making contact. The amount of current flowing through the lights has an effect on the rate at which the lights blink. I've always thought it was designed that way so you can identify if you have a light out. This is a reliable indication throughout various brands of vehicles.
Good luck,
Doug
1971 RSR - interpretation
Old 10-29-2006, 09:25 AM
Fast Blinking Left Turn Signal
I thought I had found my issue (wrong bulbs and loose rear bulb holders) but am still chasing the fast blankety blink.
Mark
'88 Carrera GPW Sunroof Coupe
'82 SC Targa (RIP)
Old 10-29-2006, 10:02 AM
