Rear M caliper rebuild
OK, splitted the halves, cleaned everything, new seals, dust boots and lubing etc in place. Painted the lot as well.
Now I would like to use new bolts to join the halves back together again, as well as new o-rings. Does anybody know where I can get the bolts and/or o-rings? Part.nr. maybe? Thanks Dennis
_____________________________ 1972 911 2.4S Black on Black, Recaro's, SSI, MFI, dual pipe exhaust, currently running in after engine rebuild! |
I'm no expert, but I am pretty sure the accepted wisdom is you do NOT split the halves...unless it was leaking at the halves, was it?
No idea where to get the bolts/O-rings. Our host would be my best guess. Why would you necessarily have to replace the bolts anyway? Seems that they would be reuseable.....but as I said, I'm no expert.
Dan in Pasadena '76 911S Sahara Beige/Cork |
+1 on what Dan said...
A search would reveal why splitting is not recommended.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Dennis-
This link on splitting calipers has lots of information on the caliper half o-ring seals, the right type of sealant, Ribe bolts, and links to torque specs for getting everything back together. Good Luck, Jim |
