 Easiest/best:  typing "http://forums.pelicanparts.com/" into my address bar on my web browser.  ;)
 For me the easiest was anything I just dropped off the car and wrote a check.  None of which have been inexpensive.  There is very little "cheap" on these things.
 Easiest upgrade? Put on prosche valve stem caps. How much easier can it get.    JC
 most recent, today.  getting the damned blizzaks off finally.
	replacing with scott mackies[thanks again scott] set of 7x16 all around, shod with kumho z rated ecstas. best thing i've done since getting h 1 lamps. next , if i can find a set of eights or nines at a good price.  |
 track time
 Removed the tacky "P O R S C H E" combination sunvisor/windshield decal installed by the PO.
 repaint fresh air screen
		The previous owner left wax on the fresh air screen.  Turned four screws and painted rattle can rustoleum flat black.
	http://forums.pelicanparts.com/uploa...1177078376.jpg cheapest: rebuild windhildshield washer fluid pump = $0.00 clean clogged filter in reservoir tank = $0.00 adjust trajectory of spray nozzles = $0.00 Wheel rehab = Scotch brite pads $3.00, rattle can rustoleum glossy $4.97 = Hours of careful scrubbing and masking tape. http://forums.pelicanparts.com/uploa...1177078910.jpg  |
| All times are GMT -8. The time now is 05:08 PM. |
