-   -   Your easiest 911 upgrade (http://forums.pelicanparts.com/porsche-911-technical-forum/312384-your-easiest-911-upgrade.html)
Hawks911 10-30-2006 06:44 PM
As a newbie on this site, I can't come close to posting pictures of my first engine drop (and fortunately, after 2 months of ownership, the engine is still running strong!). So, how about the other end of the spectrum, what was your easiest 911 upgrade?
Mine, so far, has been the decision to order two new rubber boots for the dome light door switches on our 1978 911SC. The driver's side switch needed to be replaced. I ordered a new switch but at the same time, feeling like a big spender, I ordered two new rubber boots to replace the worn, cracked original boots.
After replacing the broken switch, with a bit of solder and avoiding losing the wire through the door jamb, the new boots poped right on, and began the first step of my long journey of the major interior restoration that lies ahead.
Not bad for 2 x $2.75! And, the postage was free!
Now, let's hear of your easiest 911 upgrade.
Mike
http://forums.pelicanparts.com/uploa...1162262462.jpg http://forums.pelicanparts.com/uploa...1162262615.jpg
Tetra84 10-30-2006 06:49 PM
install of fire extinguisher.
joe payne 10-30-2006 07:36 PM
O.K. THAT WAS HYSTERICAL! Don't trust that wiring job?
Anyway, If you want a real easy nice upgrade, install a Momo
leather shift knob.
afterburn 549 10-30-2006 07:44 PM
get rid of spare tire and jack
lally911 10-30-2006 08:26 PM
Put in a nice steering wheel.
dan79brooklyn 10-30-2006 08:49 PM
Jb Welded the shift knob to keep it from spinning everytime I shifted gears!
Spin City 10-30-2006 08:57 PM
Replace all missing/broken knobs on dash and seats
Upgrade stereo and speakers
Re-dye leather seats
Replace kick panel blowers
Replace hood and engine lid shocks
Replace all oil with synthetics
Replace catalytic converter with bypass
Replace old worn door stays
Flush brake fluid
All easy and rewarding DIY projects.
Hugh R 10-30-2006 09:01 PM
Changed the fittings on the cam oiler fittings to the smaller ones and got about 1 druck of pressure increase at idle. Adjusted the throttle linkage to open complete=free! Shifter bushings, about $30 big difference.
2ndTARGA 10-30-2006 09:24 PM
A. Ordered official Porsche rubber-handled key blank to replace all metal pad lock style key,
B. New shift linkage bushings.
C. Motor and trans mounts and sound insulation pad.
Ron
snbush67 10-30-2006 09:25 PM
Installed bumper plug, cost :free, time: .05 seconds. I cant think of anything easier. Fun game though.......I win.
Gogar 10-30-2006 09:35 PM
I turned off the stereo, opened the window, and downshifted. Best stereo upgrade ever.
seriously, though; I recovered my door panels and pockets for about $30 with some new vinyl, a staple gun, and a little glue. Looks great and my friends think i'm an upholsterer now.
DarrylD 10-30-2006 10:02 PM
Right after buying my 911, taking it in to John Walker for a valve adjust, dial in the timing and CIS and to drive the car for an expert assessment of shifting and braking. Cost me a couple hundred bucks, it ran 1000% better and he gave me a prioritized project list about 10 items long that I could do myself.
Why shoot in the dark when the expert marksman can help you aim?
Spin City 10-30-2006 10:08 PM
We need to clarify the goal here: easy or cheap.
If cheap is our goal than I want to change my answer. The best return on investment was washing my 911. Looked like a new car for about $1.50.
smestas 10-30-2006 11:57 PM
Mine was adjusting my throttle linkage. You would be surprised how many cars out there aren't getting WOT when the pedal is to the floor.
JohnJL 10-31-2006 01:40 AM
Boattail your mains ;-)
KCinBR 10-31-2006 03:36 AM
Steve Wong Chip, 15 min install ,very effective
livi 10-31-2006 04:06 AM
SW chip and oil change.
Well, air filter must be on top of my list of course. If it wasn´t for the lower, rear clip it would have taken 3 minutes instead of 30.
bkreigsr 10-31-2006 04:12 AM
new points for the mfi car. gapped to precisely 38 degrees. $12.95
azasadny 10-31-2006 06:31 AM
Exactly!
Exactly! That's why Tab Tanner at Autobahn Garage in Findlay, OH has had Helga in for a thorough "going over". Sometimes, a professional mechanic is required and they can help you, the DIY'er prioritize and plan your work...
berettafan 10-31-2006 06:38 AM
Re: Exactly!
I thought that was an awesome idea too!
