Location: Lake View, NY (in the snow belt south of Buffalo)
Assuming its similar to my '87, about 10 - 11 quarts. I usually put in 9, start the engine and let it warm up, then check the level via the dip stick, adding as needed to half way between the low and full marks on the stick. I buy a case of oil so I have some on hand for topping up later.
Curt
Curt
1987 911 Coupe, Cassis Rot Metallic
Old 01-28-2015, 12:04 PM
scarceller's Avatar
Here are cut away pictures of a MANN filter I use for the 3.2L and these are very well made internally. Nice pressure relief spring and very hi quality filter material. Maybe others can cut up other brands to compare?
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 01-28-2015, 12:05 PM
Location: behind the redwood curtain, (humboldt county) california
NOT fram
In addition to pushing my dad's old 74 coupe around, I also hammer on an old 77 Ferrari 308, (aluminum, 3 litre dohc w/ 4 2bbl webbers, & a lot of suspension/brake work).
I had done a major before a track day at Thunderhill and I was jambed for time and used the fram. I drove it 200 miles to the track, ran a few sessions, then after being well warmed up, I noticed a BIG drop in oil pressure.
After getting it home, I checked the bypass plunger and spring, installed a temporary manual gauge, which confirmed a 50% drop in pressure. I pulled the filter and installed a Baldwin - INSTANT RECOVERY OF OIL PRESSURE.
So, I cut the offending pos up and here is the evidence:
Old 01-28-2015, 05:41 PM
85911's Avatar
"2nd - and perhaps more importantly - unless it clogs, the filter will be more efficient (work better) if you do NOT change it. All filters are more efficient if they have some filtrate on the media than if they are new."
True for particulate capture only. As the particles build up in the filter, the pressure drop across the filter increases there by reducing flow. Total efficiency must take into account particle generation rate, and the required/optimal flow rate to remove those particles from the system.
1985 911 Carrera Targa, 2011 911 Carrera S 997.2, 1951 Harley Davidson Panhead Chopper, 1957 Harley Davidson Panhead- stock, 1972 Yamaha 250 DT-1(sold), 1959 Austin Healey (Bug Eye) Sprite- sold, 1959 Austin Healey (Bug Eye) Sprite- sold, 1960 Austin Healey (Bug Eye) Sprite- sold
Old 01-28-2015, 07:14 PM
TheSt|G's Avatar
Pretty much confirms all of my thoughts on Fram.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 01-29-2015, 07:32 AM
