Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
glass or oem for race car bumpers
I'm thinking of going with a 964 rs look for the 912-6. Dedicated track car now.
Should I go for fiberglass front and rear bumpers, or find OEM porsche stuff? Whats best for a track only car?
Thanks!
Idea generator
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 08-29-2006, 07:58 AM
Zeke's Avatar
It's my understanding that all the mounting gear for the OEM would be troublesome for your early body, not to mention the weight. You would have an easier time, IMO, being able to glass/epoxy whatever brackets you need to the back of a FG bumper.
On the other side of the coin, you might be able to get slightly damaged 964 bumpers for a better price. I have similar ideas for a mid year car, but I plan on redoing the lower half to look more like the early S bumper with the splitter, thereby losing the elongated 964 openings.
Old 08-29-2006, 08:05 AM
Stahlwerks.com
jhelgesen's Avatar
Since my body is a 76, I thought the 964 oem stuff would just bolt on.
John Helgesen
Old 08-29-2006, 08:29 AM
Bill Verburg's Avatar
For a dedicated track car, as long as class rules allow, fiberglass
The reduced polar moment is a remarkable attribute to have.
Bill Verburg
Old 08-29-2006, 08:37 AM
Cory M's Avatar
GLASS
Old 08-29-2006, 09:19 AM
Stahlwerks.com
jhelgesen's Avatar
Okay, the majority says glass.
Next thing to do is see who has them....shaw, rennspeed, etc....
John Helgesen
Old 08-29-2006, 09:26 AM
Slippery Slope Victim
NY65912's Avatar
Shaw, my stuff fit real well.
MikeČ
1985 M491
Old 08-29-2006, 10:29 AM
Non Compos Mentis
DE, or racing?
If racing, read the rules and see what's allowed.
Old 08-29-2006, 10:38 AM
Stahlwerks.com
jhelgesen's Avatar
I didn't see the 964 stuff on Shaws website. About 1200 from Rennspeed and 1600 from Getty for a package.
I'm playing in DE right now. I've already "upgraded" my car out of the ranks with the PCA, but I'm pretty sure I'm safe with NASA.
John Helgesen
Old 08-29-2006, 11:17 AM
Alright....
Porsche_911s's Avatar
Did you find out or confirm if the OEM 964 bumpers would bolt on to a '77 car?
Stephen
Friendswood, Texas
'78 Targa
w/ '86 930/20
w/ '74 915/06
Old 10-08-2006, 10:29 AM
Getty Design makes excellent glass and c/f. Famous for fitting perfectly, and they don't use the "Hey, whaddya want, it's just racecar stuff" excuse.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 10-08-2006, 11:52 AM
Confused
I have a 964 kit on my car - also ex 912 SWB - looks good, BUT - fitting a front oil cooler is problematic, needing bodywork cutting on the front of the tub and a very low cooler mounting to use the standard air vents on the front, or cutting out the number plate area on the bumber - which makes me think FG will be best for this as it can easily be reinforced around the cut.
Squeaky brakes are safer....
2000 GT3 Clubsport, 1967 911 2.7 Track toy in progress
1983 Lamborghini Countach 5000S, 2009 VW Tuareg, 6 Bicycles - 3 Road, 3 Mountain
Old 10-08-2006, 11:56 PM
charleskieffner's Avatar
weld 4130 steel NERF BARS front and rear. saves tub in event of crash. glass will be toast but tub should survive. simple and you dont see them.
Old 10-09-2006, 04:29 AM
Jim Smolka's Avatar
The 964 OEM front bumper will 'bolt' onto your 76 912E. However, you will need all the brackets. If you were to race the car in PCA F or G class car, the additional weight of the OEM vs Fiberglass is not a factor since you the car has to weight ~2700 LBS. However, the advantage to the OEM stuff is crash protect vs fiberglass. The fiberglass stuff would have less polar momentum.
If the car is just going to be a DE car, then obviously, less weight vs added crash protection.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 10-09-2006, 05:00 AM
Stahlwerks.com
jhelgesen's Avatar
Update.
I now have glass front and rear bumpers, and oem side rockers, from another Pelican. Have to complete some work on the wifes targa before I can install though.
Next question is what splitter should I use on the front? I've seen two piece and one piece designs. I'll be using my duck on the back for now.
John Helgesen
Old 11-03-2006, 08:13 AM
