-   -   Weber float bowl mod epoxy type (http://forums.pelicanparts.com/porsche-911-technical-forum/313318-weber-float-bowl-mod-epoxy-type.html)
Russellh911 11-05-2006 08:05 AM
Since I'm into rebuilding the carbs, thought I would do the float bowl mod and add the dam in the bottom. I've searched the archives unsuccessfully and Jerry doesn't specify in his book, so the question is: what type of epoxy works?
I did see a picture posted showing a set that were sent to Jerry Woods, and that looks like good old JB Weld, but that doesn't mean it's so. Do I need some custom $80 per kit type product that can survive immersion in gasoline?
Thanks,
Russ
gumba 11-05-2006 08:21 AM
JW mills a shelf in the bottom of the float bowl that the plate sits on before it's epoxied in. There may by other work involved. I posted a shot showing the mod.
raceman 11-05-2006 08:25 AM
use the epoxy sold to repair gas/fuel tanks,it`s a slightly different formula and available at large auto parts places
Russellh911 11-05-2006 08:31 AM
But any idea of the epoxy product he uses?
Russellh911 11-05-2006 08:32 AM
Thanks raceman, I posted back to Gumba just as your hit. I'm off to the store.
