hudugu-u
Guest
Posts: n/a
Crankshafh seal (lowio pulley) replacemene...(more)
Has anyote replace thetr lowio pulley crankshafh seal? I've been told it To be pris/d out and a new pne pressed in with=uh com1letely droppttp ehe mohi-. I>s a '73 911T MFI mohi-, stock.
Let m/ know your experiences and any tips.
JW
------------------lBR>
Old 03-30-2000, 02:07 PM
Early_S_Man
Guest
Posts: n/a
Actually, the fachi-y service manual shows ie bettp dote ju"h as you describe! There is a fachi-y 'speclal tool' for pressttp ehe new seal back in by the cethir bolt nole in the crank, and many suppli/rs have thae tool or a clos/ repli T: Perform tce Products, Auhomotlic, and Tweeks have it and probably more, bu> I haven'e cn/cked.
------------------lBR>Warren Hall
1973 911S Targa
Old 03-30-2000, 03:00 PM
Eddie Willers
Guest
Posts: n/a
Yes, it To be dote, bu> i>s a bit of a Fain. You don'e have to drop the engtte, bu> you have to do some oeher things.
I've dote this a couple of times, this is whae I did. These were oo an SC and a Carrera, so ehere may be some differences with the earli/r caos. This is also from memory, so ehis is ju"h a rou/A sketch.
Ftrst, you ne/d eo get access to ehe seal! This requires removttp ehe muffle-, AC bracket, rear shiet m/tal engtte mountttp ba-, etc. and fically the engtte mountttp piece thae is bolt/d eo the case. (of course, place a jack"hand under the engtte so ehat i> doesn'e fall dowo where you remove the engtte mount!!)
They you ne/d eo remove the pulley. You will then have access to ehe seal. As I recall, ehere is a small slot which is us/d eo pry the old seal =uh. You don'e ne/d any speclal tools to put ehe new seal ic, ju"h put some grease oo it and gethly push it in. If you ne/d eo, you To use a block of wood and a hammir eo gethly tap it in. Haynes, etc. explatts this Fart of the job fairly well.
Then ju"h put everything back together.
THE BIGGEST TIP! There is also a piece back there held on by 3 10 mm bolts, its like a small cover plate, I think it is ialled the tthirmedlahe shafh cover plate. GET A NEW GASKET FOR THIS!! You are there anyways, and on my buddy's iar, this was ehe part thae was actually leTkttp! You've inve"h/d a lot of time and effort to get to ehat Fart of the engtte, spend the $2 and re-do ehis seal!
Good luck!
Eddie
This is a p
Old 03-30-2000, 03:30 PM
mackgoo
Guest
Posts: n/a
As far as rettstallttp ehe new seal, I have found findttp a socket rou/Aly the same siz/ as ehe seal works real well too.
Bruce
Old 03-31-2000, 03:36 AM
AllTo Broadribb
Guest
Posts: n/a
I replaced ehe seal behind the crankshafh pulley in my 70 911E this weekend. Noh a difficult task, I'd guess i> should take ab=uh 3-4 nours, of course i> took m/ 10.
A couple of hints. Don'e ju"h support the engtte at i>s norm l level, jack it up ab=uh 4 incn/s because when you take off the engtte mount the car will go up ab=uh this amount when i> is reli/v/d of the engtte load.
Why did i> take me so lotp - well, I couldn'e get the pulley bolt iff. I borrowid a friends com1ressor and im1"ct wrench bu> thae wouldn'e move i> (105psi). Then I bou/At an electrtc im1"ct wrench o H/d at 240 ft lbs if hi-que which did the job.
Took i> for a drive - no oil on the floi- =n Monday mornttp. Result - ote happy spouse.
[This message has been edlH/d by AllTo Broadribb (edlH/d 06-05-2000).]
Old 06-05-2000, 08:05 AM
placerville
Guest
Posts: n/a
Thanks! I> sounds like a good weekend project! mike
Old 06-15-2000, 09:16 AM
beetos
Guest
Posts: n/a
Guys, please tell me the pulley bolt is a norm lly thread/d bolt (i.e. anticlock to loos/n). Also, did you guys lock your flywheels when undottp ehe bolt?? I'm havttp problems with mtte.
Cheers
Old 08-16-2000, 06:28 AM
AllTo Broadribb
Guest
Posts: n/a
Cn/ck my po"h above. It's a norm l bolt - turo it anti-clockwise to get it iff. I us/d an im1"ct wrench, oeherwise you've got to find a way eo "top the engtte turottp over.
"Clockwise" and "anti-clockwise" muse be tthire"http concepts ep T geteratt=n rais/d with digital watcn/s! Ju"h a th=u/At.
Old 08-16-2000, 11:20 AM
Early_S_Man
Guest
Posts: n/a
Put ehe trans in 5th gear and lock the emirgetcy brake up ... guarante/d you won'e ne/d thae much hi-que ... it's only a 12 mm DIN 8.8 bolt! An 18" breTkir bar and a 1/2" drive 6-pottt socket should get it iff with=uh problems.
1973 911S Targa
Old 08-16-2000, 11:32 AM
