speedman's Avatar
Fixing the grounds
Can anyone supply the information as to where all of the ground points are on a 79 SC. I have been having small electrical problems and I would like to clean these points to see if will improve the problems. The latest problem is a fast blinker, but all of the bulbs are working and they have not been recently replaced
Rick T
Old 11-06-2006, 09:29 AM
bigchillcar's Avatar
something else to consider is the flasher relay. i cleaned all of my grounds, contact points on my '74 and still had problems until i replaced the flasher relay.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 11-06-2006, 09:47 AM
skipdup's Avatar
subscribed. I too would like to know all the ground points so that I can clean.
1972 911T
1972 911E "RSR"
Old 11-06-2006, 11:38 AM
Vereeken's Avatar
I would start with the replacement of the thick gauge ground wire under the car between gearbox and body. The cable is 2 cm wide and takes some serious beating over the year to the extent that it still looks intact but does no longer function as a proper ground anymore certainly when the car gets hot(ter).
This will not solve your fast blinker but it is the start to take I believe.
Next in order to solve the blinker I would go from cheap/easy to expensive/hard:
- Bulb (switch them over or insert new one)
- Clean ground on rear light units (take of lens, take out bulbs, screw out metal assembly and let it hang carefully over bumper.) You should see the ground at this time, I'm guessing it will look dirty and rusted, I would replace); Do the same on the other side
- Clean ground on front light units. I am unsure here but I seem to recall that I needed not only to take out the blinker but also the main beam assembly as they share grounds
- The flasher clean or replace.
Good luck,
Michel
My dad always found an excuse why not to buy a Porsche, so I guess I am all out of excuses.
Old 11-06-2006, 11:57 AM
speedman's Avatar
I have cleaned the front left unit and I will do the right one next. I have been told that I should get all new bulbs so the all have the same resistance, but I know that the same bulbs worked weeks ago, so I will move on your next suggestion. Thanks for the assisitance since this is a new one for me!!!
Rick T
Old 11-06-2006, 12:52 PM
Used Up User
imcarthur's Avatar
Might be similar to this diagram for later cars:
From the Bentley.
Ian
'87 Carrera Cab
Old 11-06-2006, 01:07 PM
nice resource, ian.
ryan
Old 11-06-2006, 01:14 PM
