User
Jacking Up Low Front with Chin Spoiler/Valence
My jack won't fit under my very low front end. I need to get the front up on jack stands. What are some fellow Pelicans' methods for doing this?
Covered in other threads, I'm sure, but can't seem to find them right now. Thanks.
82 Targa |
I have made low (1 inch) ramps out of mdf board glued together that I drive up on.
Then I can get under with my jack.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Driving member
Yeah just get a 2x10 long enough to allow both sides to drive up on.
It also helps to have a low profile jack.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Jack from the side
Used Up User
Use the jackpad & jack high enough for jackstand placement in rear. Also slide a thick piece of wood, paving stone etc under the front wheel while it's up in the air. Repeat on other side.
THEN you can easily slide jack under front for front jacking. Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
I'm with Bill
I remove the pad from the jack and slide it under the car. I place the front tow hook into the hole in the jack where the pad went. works like a charm. I also only have 4 inches of clearance in the front.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
If your car is anything like mine you are not gonna jack at the front
I also made ramps from 2X12inch boards. Drive up then jack.
Eric
'79 SC Silver over Black... Sold |
User
Alright guys, thanks for the input. I'll take if from here.
82 Targa |
I jacked from the side (corner of the pan behind front wheel) after removing the cup from my floor jack. I put a thin piece of 2 x 6 on the jack to protect the pan.
You can try one of these, too: My car is pretty low:
good lord.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Bill and Danny, Can't tell if yours are track or street cars. If the latter, are there any tricks for negotiating simple parking lot speed bumps and inclined driveways? Just curious because my 911 is barely lowered and I still occasionally bottom out the RSR front bumper/spoiler--oh, I am running super low 205/50x15s on the front!!
Phil Y, Kapolei, HI 04 BCR (not quite stock), 06 Buell Blast (grandson's first bike), 77 R100S w/sidecar "There are old riders, and there are bold riders, but there are NO old, bold riders!" -My first MSF instructor, too many years ago |
A very low car is no longer a street car in the usual sense.
That's another story . |
It depends on your jack too, I can get a harbor freight aluminum under mine even at cup height.
The C3 is no problem even w/ my old reular cast iron shop jack. The 993 needs some extra pads to even get it over my lift w/o the white 3/4" plywood the brake scoops don't clear.
The jack point shown on the "stolen" pic can be vulnerable on an older car, especially if there is any rust present (when isn't there? ) Most of the cars I get to see from the bottom ahave caved in there from the 4 pt. lifts used over time. Then, there's the oil line liability. I'm not going to revist the thread I linked, I'll just say I have my tried and true point to raise the car, albeit a little at a time, each end, until I've reached the height I need. I have found that just doing engine work, ass end up and front on the tires (as long as your spoiler/splitter isn't being bound) gives a good working angle and height without having to raise the car beyond the lift range of the common floor jack. I'm sorry, but I do this using the engine case and a wood adaptor I've made for each engine. I don't do the Boxster that way, however. I use the dedicated points and 2 jacks.
Here's MY pic re: jacking points. Disclaimer: Anyone/everyone has my express permission to use this pic in any way they see fit, with or without credit, payment or acknowledgment of any sort...
