Had the same issue happen to me a while back. If the vehicle is at home. Remove the ignition switch mechanism from the dash in its entirety and take it to a locksmith to have it cleaned/repaired and lubricated. If the mechanism's not damaged this should do the trick. If it is you'll need to replace it . I've got a 70 911 with the original switch that has been handled this way since new.........
Dirty Marty Fallbrook, CA |
I agree with Phil - lock graphite is specifically made for this purpose - how could it be bad to use??
if my memory is correct... pelicanhead "safe" said WD-40 is the what to use. He does locks for a living.
maybe do a search.. I would but I'm not at home on my machine.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
If all other lube attempts or lube combinations fail, Super Dave might want to remove the switch and follow Dirty Marty's suggestion. For Plan B, I think a new ignition switch for an '88 is pretty affordable, not like earlier versions which are NLA. Sherwood |
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) |
Yeah, I guess the $532 is not in the category of affordable (to me anyway). I might have been thinking of the electrical portion of the two-piece switch. Isn't that "less"?
Or compared to NLA, $532 is affordable. For that price, I'd see what VW has to offer. Sherwood |
Here are a few of his comments: Quote:
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 11-08-2006 at 05:47 PM.. |
if your key looks to be in good shape id take the whole switch out and spray it out with wd-40 and blow it with compressed air. the let it dry out completely for a few days and use graphite. just my .02
82 SC , 72 914 |
WD40 leaves an oily residue. If one is to clean the insides of the ign. switch, why not just do it with some spray solvent instead of WD40 which the graphite would stick to. Let it dry as suggested, then apply the graphite.
Sherwood |
I replaced my ignition switch and did not have to rekey because I got the original emergency key AND THE NUMBERED TAG from the previous owner. I was very lucky. I used this number to order the replacement from the Porsche dealer and received the new switch keyed to my original key set. Hopefully, you have that key tag, which is red and white with a 3 or 4 digit number stamped on it. Good luck.
1987 Carrera 3.2 |
