69T 901 Transmission Problem
I have a 901 five-speed 69T. I believe that it is the original transmission and the car probably hasn't been moved since 2001. I can’t get the clutch to disengage to change gears when it is running. I can move though all the gears when it is not running except for first. I’ve never had a problem with a manual transmission before so I guess I’m lucky but, on the other hand, I’m not even sure I’m making any sense. Thanks!
"I spend my money on cars, women and alcohol. Anything left over I spend foolishly." '77S Metalic Viper Green Targa '69T Daily Driver '83SC Euro '67 Bondo Miracle |
the disc is stuck to either the flywheel or pressure plate. warm it up, so it starts easily, shut it off, put it in 1st, keep the clutch to the floor, crank the key and go light on the gas so you get rolling, then go on and off the gas to break it loose. clutch to the floor at all times.
Thank you John.
I had considered that clutch disc was stuck to the flywheel but I had never heard of it happening and I couldn't find a thread about it. One fly in the ointment. I can't move into first gear when the car is not running. I can try using reverse by I am am wondering if it is related to being stuck or another problem. All others will let me in when the car isn't running.
I agree with John, the disc is stuck to either the flywheel or pressure plate.
I would alter the procedure only slightly: Put the transmission in neutral. Start and warm it up, so it starts easily, Shut it off, Put it in 2nd, keep the clutch to the floor. Crank the key and go light on the gas so you get rolling. Then go on and off the gas to break it loose, clutch to the floor at all times. My reasoning is that the input shaft 1st gear position is not particularly strong. This process is somewhat stressful to the transmission. This lessens the risk of a problem. If the 911 is parked where it won’t conveniently start and run in 2nd, use first and reverse to get the car headed slightly downhill before starting and proceeding in 2nd gear. If it won't go into a gear, let the car roll a little in neutral - forward or back, it doesn't matter. Never try and change gears while the engine is running and the clutch won’t release. This will damage the syncros, engagement dogs and sliding sleeves. Be gentle with the engine. This is more difficult on it than starting and break-in for a freshly rebuilt engine. Keep the revs low and only start for short periods initially. A lot has been discussed about this on Pelican and other. Check your brake fluid. You don’t want a master cylinder failure to have you with no brakes! Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Thank you John and Grady.
I'll try it tomorrow. I'll let you know if I wind up on someone’s lawn.
check the pivot.. go under the car and see if the clutch fork can be moved side to side by hand.. if so,, the fork pivot is broken..
I don't do it with the P-car but nearly every other manual I drive I often shift without a clutch. I do this as practice for matching revs when heel toe driving. What the hey, wife's Cavalier is still under warranty (just don't let her know I said that)
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
Milt my friend,
No No No, you mis-understood. You can’t have a 911 rolling and push the shifter into gear. That will almost immediately damage something. I think what you are referring to is being able to “bump start” a 911 by letting it roll in gear with the clutch released and then suddenly engaging the clutch. This only works with a properly operating clutch. In this situation the clutch pedal is depressed but the clutch isn’t released. From the description, John, my and others impression is the disc is stuck to the flywheel. Only if that is the case will possibly this technique work. No guarantees. There is also the possibility of damage as I indicated above. In spite of that, I think this is a reasonably worthwhile attempt. I have seen it work. If the pivot were broken, he wouldn't have any clutch "feel." The pedal would be at the floor with no resistance. As I said above, shifting without releasing the clutch (or attempting to put it into gear without the clutch fully disengaged) will probably result in damage. Urban, if you have ANY question about the procedure or risk of damage, ask before you do anything. Best, Grady
