North Coast Cab's Avatar
Help - 3.2 Into Race Car
I started this thread 14 Pin Connector Wiring Diagram
but I thought this would be a better subject. Looking for those who have transplanted a 3.2 intoo a race car. I need to figure out whta to do with the 14pin connector coming out of the wiring harness since there is no harness left in the car.
TIA, John
1985.5 944 GTS
Old 11-12-2006, 04:25 PM
Anyone? I have the engine harness and all the connectons to the 3.2
I can make the coil connection and the connection to the DME. However, there are several connections I don't know and I need to find outif they are pertinent to the motor running or not.
TIA, John
1985.5 944 GTS
Old 11-13-2006, 04:50 PM
randywebb's Avatar
there is a pin out with a color diagram in an old thread if you can dig it out with the search engine
othesie you'll need to got thru a wiring diagram with the info that guy on the other post gave you...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-13-2006, 05:31 PM
