early heat exchangers
Would these work similar to SSI's for a 3.2?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&ih=010&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=200047111528&rd=1&rd=1
cheers,
Phil
84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies.
Old 11-13-2006, 10:37 AM
PRO Motorsports
Tyson Schmidt's Avatar
Yes.
Not quite as good, but similar performance.
The SSI's are equal length both sides. The stock early exchangers are slightly unequal on the passenger's side to facilitate easier install/removal.
Also, I've found the primary pipe I.D. to be much more consistent on the SSI's than on the old used factory HE's. SSI's are always exactly 35mm I.D., and I've seen many factory sets where some were 35mm, and others were as small as 33mm, presumeably from warpage.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 11-13-2006, 11:39 AM
Would you say an improvement on the stock 3.2 setup?
cheers,
Phil
Old 11-13-2006, 11:49 AM
PRO Motorsports
For the street, yes. it will sound better, and improve throttle response and low-mid range torque. You may lose a little at the upper extreme of the rev range though due to the smaller primaries.
2004 GT3
Old 11-13-2006, 11:52 AM
Thanks Tyson.
I'll go check them out.
I think they're down the street from me.
Oh, I forgot, will all hte heat heat and muffler stuff bolt straight into them?
cheers,
Phil
Old 11-13-2006, 11:58 AM
PRO Motorsports
No, you'll need an early muffler, early oil lines, and early engine tin and heat ducts on the motor.
2004 GT3
Old 11-13-2006, 12:11 PM
