Front lowering question
82 911 sc.
I dropped and evened out the front but woiuld like to go just a bit lower. It appears the driver side torson key lever is not at the same place or distance from the screw adjuster as the passenger side. Is this just a simple slide off and reset the key or is there another problem I am missing?
D.Brisson
Old 11-12-2006, 01:12 PM
I'm with Bill
Rick V's Avatar
Once you completly remove the adjustion bolt from the mount the adjuster will simply pull off the tortion bar. make sure the felt seal is still in place when reinstalling. It will be obvious when you pull it apart.
Old 11-12-2006, 01:16 PM
