-   -   dash swapping (http://forums.pelicanparts.com/porsche-911-technical-forum/314917-dash-swapping.html)
cerberus1 11-13-2006 11:16 AM
dash swapping
Can anyone tell me which year models (particularly 70's -80's) would share dashes? Ie: can I put a '77 dash in a '73, etc? Are there any peculiarities in mounting, etc? Hope someone can share their knowledge here...
Bobboloo 11-13-2006 11:38 AM
I think 77' in a 73' would work. Before 72/73' the stud spacing was a little different but can be worked around using a drill to add a couple extra holes.
Tyson Schmidt 11-13-2006 12:54 PM
Yep the stud spacing is different on the face, and also on the top where the stud sticks down behid the gauges.
Also, you'll need to cut a square hole so the center vent will fit. '77 was the first year for the center vent.
Tim K 11-13-2006 03:13 PM
Backwards, but you can see the difference between them here:
Early dash in an SC:
http://forums.pelicanparts.com/uploa...1163458429.jpg
On the right the stud on the dash is hiding just between the vent opening and the mounting hole.
http://forums.pelicanparts.com/uploa...1163459509.jpg
Hope this helps
Tim K
