ASD ASD is offline
ASD's Avatar
Switch gets hot
The rotary fan speed switch for my a/c fan ha stopped working on any speed other than low.
Today I noticed with it running on low it got very hot. Could not even touch the metal parts.
Replace the switch? Or anything else to check out?
its on a 78 911Sc
1999 Carrera2 tip arena red
2000 Boxster S tip...arena red ....black
1981 911sc targa...grey mkt.import...Rosewood
1978 911SC, guards red sunroof delete .much missed
73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead.
Old 08-11-2013, 08:06 AM
Banned but not out, yet..
RSBob's Avatar
First, I would make sure you still have a good ground for your switch.
Old 08-11-2013, 08:19 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Heat in electrical parts is caused by resistance.
Resistance is an indication of a bad contact or joint.
Anytime you feel heat from any electrical part...investigate the cause...it might just be a dirty connector...or a loose joint.
Bob
Bob Hutson
Old 08-11-2013, 08:58 AM
ASD ASD is offline
ASD's Avatar
Ok will check that out...thanks
Old 08-11-2013, 09:15 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Resistors.
Also, have a look at the blower resistors connections located at the front
bulkhead ahead of the passenger seat.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-11-2013, 09:39 AM
ASD ASD is offline
ASD's Avatar
blower resistor "looks" perfect. Any way to measure it?
wires on back of rotary switch have corrosion on one of them...tight in there but I need to get the switch out and clean up the connections.
Old 08-19-2013, 11:47 AM
Switch removal.
Be verrrrrrrrrrrry careful with the A/C temp switch capilary tube.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 08-19-2013, 02:06 PM
