User
ikarcuaso's Avatar
DIY WUR Installation ?
Is this something a relative noob can handle? If so, can someone point me toward some related threads and/or links (sorry, maybe I'm not searching the right keywords or whatever). Or should I just pay the man?
If it's straight-forward enough, and another Bay Area pelican is willing to hold my hand for beer and/or food, that would work, as well.
TIA for any input.
82 Targa
Old 11-12-2006, 11:49 PM
oneblueyedog's Avatar
Easy.
Make sure motor is cold. Have a fire extinguisher at hand. Get a rag to catch the fuel dribble. Carefully dissconnect the wiring plug to it. Disconnecct the vacuum hoses to it, top and side. Get the rag and put it underneath the WUR to absorb fuel. Take your 14mm wrench and disconnect the WUR to fuel distributor line and drain it into the rag. Move it out of the way without kinking it. Disconnect the other fuel line banjo fitting (mine's a 78 with nylon lines). Carefully remove it with the 2 copper washers and nut (locally difficult to find parts). Put them in a safe clean place. Get a 5mm hex socket and remove the bolts that hold it to the intake runner. Remove the fuel fitting from the old WUR and put it on the new one. Install the new one. Check for leaks. Before cranking, lift the sensor plate up to fill the return line with fuel (don't overdo it). Check for leaks again before starting the car!
Hope it helps.
78SC coupe, Silver Metallic
Old 11-13-2006, 05:47 AM
The only thing I would add to the above description is to be careful when trying to break loose the mounting bolts for the WUR. Mine were pretty rusted, and I ended up breaking one of them. Then I had to spend an hour getting the remaining piece out, using vice grips in an area that doesn't really have room for vice grips.
So it may not be a bad idea to spray the bolts with PB Blaster or similar a few times before you start. Try to get some into the area where the bolt threads into the flange at the bottom of the intake runner, if possible.
Good luck
Scott
1978 911SC RoW
work in progress
Old 11-13-2006, 07:12 AM
vash's Avatar
easy, but if you need help, PM me.
poof! gone
Old 11-13-2006, 07:45 AM
Hilbilly Deluxe
emcon5's Avatar
What makes you think your WUR needs to be replaced?
Tom
82 911SC Coupe
GTI Cup #43
Old 11-13-2006, 08:22 AM
User
ikarcuaso's Avatar
Tom
Because I have a replacement WUR sitting here. And replacing the AAR didn't seem to help my cold start problem. And I'm completely caught up in this ghost-chase.
Oh yeah, and my control pressure when cold appears low, ~10 psi or so. Unless it was measured wrong.
Gotta love CIS.
Vash, I appreciate the offer. I'm gonna stare at my engine a bit more, and then I'll PM you.
82 Targa
Old 11-13-2006, 08:40 PM
Vash knows CIS better than most. You should take him up on his offer, and I'll come by to lend more support and drive you both crazy by going on-and-on about the wonders of carbs. I will add this to your ghost-chase hit list: never underestimate the annoyance factor of the decel valve. Before you do anything else, you should plug the vacuum line to make sure that it isn't the source of your woes.
Old 11-13-2006, 09:55 PM
User
ikarcuaso's Avatar
Great! Just lmk what kind of beer you guys like!
Yup, I plugged the decel valve's vacuum line.
82 Targa
Old 11-13-2006, 11:10 PM
User
ikarcuaso's Avatar
Well, that seemed to do the trick. vash, thanks for not laughing at my cool collar ...and for your help!
82 Targa
Old 11-18-2006, 11:10 AM
