Too Many Front end choices. Hep!
I have a narrow body 79 SC Targa in GP White. I want to remove most of the black trim bits so I have started with removing the rear accordians and impact bumper and repalaced it with a Ruf F/G piece. I am ready to do the front and I like the look of the Ruf, the IROC and the C2. The Ruf has a nice shape, but it looks a little low at the bottom. The IROC looks good , but it does not have a place to put fog lights and the C2 has the brake vents that I like. How about some discussion to help in the decision making process.
The Ruf bumper cap w/o the separate rubber chin won't be too low, w/ the rubber chin it can hit on relatively severe transitions, as seen at many driveways. This is even on a relatively low car. The reason it's not an issue is the deep setback, very close to the wheels.
On a spoiler which has the leading lower edge placed further forward it becomes more of an issue. |
I know your car has a ruf front end. Did you look into a C2 or was it always going to a Ruf car? I like the way the line of the C2 flows off the hood into the bumper, but the long single bar in the front opening looses something.
IMO, If you want a perfect front end get a 993 or go back to the '73RS look |
Why would you start with a 993. A 73 Rs would work on a SCjust as well wouldn't it
The IROC would look funny without an oil cooler.
The does look nice. what type of smile are you using? I have been told that a C2/4 is a good way to go. Where did you get your F/G?
Rennspeed bumpers with 964 smile.
I plan on removing the bumper shocks and all the mounting hardware and mount the bumper with aluminum. How did you mount yours?
How close is a 993 front end to matching up w/o mods?
Speaking of which, I'll bet Bill was simply saying he likes the look of the 993 front end, rather than suggesting you bolt one on to your car. I could be wrong. |
+1 for Rennspeed RUF-style with 964 smilie... ;) http://forums.pelicanparts.com/uploa...1163790981.jpg
I see you have replaced the side marker lights with air ducts. Are they functional and how much work was needed to get the look right.
it is hard to go wrong with ruf anything
remember he has all sorts of technical facilities in Germany -- ruf doesn't just say 'hey, this looks cool' - they test |
Is there a certain year 964 smile or will any year narror body work. Is the smile list in our sponsers catalog?
RT, the duct that replaces the right side running light forces more air into the oil cooler. Does it work? YES!!! It bolts right in exactly where the light assembly mounted (minimal fuss). As far as the 964 smilie, they are all the same. You can order both parts from Pelican.;) (Although, they had the part # listed wrong from the illustration they had on the site...just "talk it through" with the rep who takes your order...Maybe they've fixed it by now).
Thanks for the information! i will get my parts on order
964 505 143 01c is the black seal that goes across. attach the top side of the bumper with 964 505 021 00 rail.
The rail can be modified slightly to mount to the 74-89 tub, then the bumper slides over it, holes drilled to correspond to the rail, then the seal mounts to that in the center- makes a cleaner install |
Sorry, but I don't quite follow. Do you mount the smile to the bumper and then mount the bumper to the car or mount the bumper to the car and then mount the smie?
how about a closeup of the smile on the car?
mount the center rail to the center tub- align it so the bumper slips over it. drill holes thru the bumper so they line up with the ones in the rail.
install the smile on the bottom of the fenders leaving the center section loose- slip the bumper on for the final time , making sure the smile is on the upper side of the bumper- use the holes in the smile to attach screws through the bumper into the mounting rail simple? well not completely- you need to line up everything first to make sure the fit is correct. if you have the smile too far back, the hood will not close completely without you having to pull the smile rubber up over the hood lip. so be patient and test fit everything before drilling and making your final mounts |
I ran the 964 rail part number through Pelican but there is no pic available. Anyone have a pic of this part? There is a verticle lip on the back of the Ruf bumper that butts up against the front of my SC tub. I would think this lip would not allow you to slide the Ruf bumper over this 964 rail. I'm confused....need pics! Thanks for the help. |
screw conformity....go your own way
http://forums.pelicanparts.com/uploa...1163868953.jpg -before fog lights and oil cooler. lol however, i guess it still have the rubber at the side.... though most people don't notice it w/e you pick i'm sure it'll be an improvement....as long as it isn't a slant nose |
i vote for stock
| All times are GMT -8. The time now is 11:53 PM. |
