ecm911's Avatar
Airbag light on after changing battery?
I have a 93 964 RSA. Battery went dead after I left the key in the ignition in the ON position for 5 hours. I was going to replace the battery soon anyway.
No problems pre battery change. But now the airbag light ( on the dash) stays on.
Any hep in attacking this would be appreciated.
Anyone every have this problem?
Thanks,
Earl
78 SC Coupe
93 RSA (Gone)
Old 06-08-2005, 11:10 AM
911mot's Avatar
Try disconnecting the battery for ten minutes. (with the key in the off position.) and see what happens
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 06-08-2005, 11:15 AM
A piece of black friction tape the size of your thumbnail works wonders...
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 06-08-2005, 11:28 AM
Todd Simpson's Avatar
You may need to have a mechanic reset the light with their diagnostic computer.
I had to do that on my '98 A4 after removing the airbag to change the ignition switch.
Old 06-08-2005, 11:46 AM
Did '93's have OBDs? Maybe. Maybe it was the OBDII that started in '95. I have my own OBDII software and harness ($395) that works through a Palm Pilot.
Stephan
Stephan Wilkinson
Old 06-08-2005, 12:44 PM
bigchillcar's Avatar
same thing happened to me tonight after installing a new stereo. i also have the seat belt and convertible top light on??! i was actually supposed to disconnect the negative terminal for the install..read that after the fact. how did you resolve your issue?
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 01-24-2007, 08:41 PM
one of gods prototypes
bell's Avatar
unhook the battery for at least 10 minutes, do this with the key off and it should reset.....
Brought to you by Carl's Jr.
Old 01-24-2007, 09:16 PM
bell...have a thread on this problem in the 964/993 forum - check it out. i'll be posting a lonnnng thread about that stereo removal and new install. a nightmare..took me and my brother about 8 hours - half of it removing old stuff. you should see the box of wires and old components..probably 20 lbs worth! i also posted on rennlist. 5 minutes did nothing..don plumley suggested overnight, so that's what i'm doing. he says i also may need the hammer or the other pc-based code reset tool..
ryan
Old 01-24-2007, 09:22 PM
