smoke
When starting I have seen smoke after driving in town while air temp is around 100 degrees. First time was at the end of the pca local meeting and my first time. Really impressed everyone. I replaced all of the injectors with new original thinking they were leaking. Cured my rough idle problem and runs super. Today after driving around town again smoke at start. I run synthetic 5-50w and us less than a quart every 2k. What is this smoke? thanx r.t.
84 m491 (mine I love my car) 94 4x chev truck ( I love my truck) 2006 honda crv ( wifeys car) 2000 camaro ss 485 hp ( son's car I hate this car) Last edited by rteague; 09-02-2006 at 08:12 PM.. |
I believe you are referencing the smoke that is emitted from your exhaust upon starting the engine after it has sat for about thirty minutes, is this correct? If so then it is normal and you will see it usually every time you start your engine usually when it has cooled down. I believe what happens is because of the angle of the cylinders that escess lubricating oil leaks into the combustible chamber on front of the piston and is burnt upon firing. it is immediately burned off emitting a pleasant cloud of smoke. You should learn to love and enjoy it.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Mine smokes for a long time before it warms up. Probably about 10 minutes
Mine does in the morning if it's cool and moist outside.
In the garage it's fine but once the exhaust touches the cool air I get a steam cloud till I get moving.
John D. 82 911 SC Targa-Rosewood 2012 Golf TDI |
r.t.
Try letting the car ilde for a short time (10-15 sec) before turning it off. This pumps the oil back into the oil tank and seems to help minimize the smoke at start-up for many. Watch the oil gauge, it will rise as you idle, when it stops, turn the car off. Good luck Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic |
