Randy Blaylock's Avatar
Cayenne brake caliper ???s
Anybody have the specs for the Cayenne 6 piston calipers?
For instance, Pagid pad P/N or pad annulus, radial mounting hole bore size and spacing, offset, piston diameters, what size are the rotors, etc...
Old 10-17-2006, 04:33 PM
Me like track days
Craig 930 RS's Avatar
No, but you might try a post on Rennlist regarding the GT3 6 piston steel brake setup. Larger pad area, more common application and usually less expensive.
Plus, if you search around you'll find that people have adapted them to other applications. Perhaps even your Viper.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 11-20-2006, 08:03 PM
