-   -   Tail light unit - How do I disconnect wires ? (http://forums.pelicanparts.com/porsche-911-technical-forum/316137-tail-light-unit-how-do-i-disconnect-wires.html)
Danskeren 11-20-2006 10:23 AM
Hi,
I trying to take out the tail light unit on my 911S from 73. But the wires are all black covered with a thick layer of Dinitrol.
How/ where are the wires connected ? and how and where do I unplug the wires ??
Any help much appreciated - especially pictures showing what I should expect under the Dinitrol. Thanks.
Best regards
Peter
poorsha 11-20-2006 10:51 AM
The wire connects with a multi-pin round plug to a receptor in the body.
Look inside the engone compartment and you will see the wiring harness fitted to a round connector in each corner.
Danskeren 11-20-2006 11:13 AM
Poorsha - thanks. Yes I see the connector inside from engine comp. Is it the same connector type on the outside ?
Peter
poorsha 11-20-2006 07:52 PM
Peter,
the plug in the engine compartment will put out.
The tail light has a female plug that is press fitted into the body.
