Bilstein Strut Insert Install: Gland Nut Not Flush
http://forums.pelicanparts.com/uploa...1164249988.jpg
I know I've seen this before on a previous search... Just installed one of my new Bilstein Strut Inserts in my Boge strut housings. When I tighten the "gland nut" it doesn't seem to tighten to the point to where it is flush with the strut housing, leaves about a 4mm gap. Is this normal or should it be flush. If flush, what's the deal? Thanks, Gordo |
AFAIK, that's correct. Because it cinches the insert to the bottom. If the nut bottomed out, how would you know if the insert was tight to the bottom? If loose, that would make a hell of a noise banging up and down.
Thanks Milt
On to another Newcastle and the other side...
Gordo |
Gland nut
I am a technician at Bilstein Shock Absorbers in California. As long as the nut is tight then it is ok. If you have any other concerns concerning your Bilstein Shocks feel free to contact me or go to the website at www.bilstein.com
| All times are GMT -8. The time now is 04:22 PM. |
