Driving member
I think doing an RSR depends on whether or not you are going to do the work yourself. If you love projects and tearing apart a car and rebuilding it does it for you, then you should go for it.
On the other hand if you are going to farm out most of the work just to get to the end result then you should sell it and go for a project that is done or at least close to done. The cost of having others do it will be much more in the long run and not near as satisfying. Just my .02
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
you would probably be better off selling and buying one that is done, it will cheaper then converting your car, Kevin
The wisest thing is to sell it and buy something else to cut up.
However, if you decide to keep it and mod it, please dont do another RSR. Go with an ST look and keep it all period 71. Perhaps its just me, but upgrading an S to ST using all the correct parts is more sympathetic than making an RSR replica from it. Besides, a lot of people feel that the RSR look is a bit played out. Just my two cents
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/ 1970 911S, 10 sec 67 Beetle (300 rear wheel HP) RGruppe#252 |
wow, again thanks for all the input. The original color was tangerine. Selling is not an option. I've thought about it many times when not looking at the car
. This isn't just a hunk of metal that can be replaced, it has a soul and a personality. I love this car, plus it is the first Porsche that I bought. If I could sell I wouldn't have started this post. I knew nothing about wrenching before I owned this car, now I'm the guy my friends come to when they have a problem with their cars (now all they'll have to do is buy Porsche's and I'll be happy to do it for them) I plan on doing all of the work myself except for paint and the machining of engine parts. I have considered the ST, it would be period correct but I really don't like the look of the ST flares. Thanks Kevin
'73 914 2.0L |
You are under no obligation to restore the car because it is an "S". You are also under no obligation to sell it and buy something else for a project. It is your car, build what you want to drive!
flame away ![]() Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
My vote is for an RS conversion. Without the original engine it's not a viable canadate for a restoration to original. Plus a good restoration to a RS would be worth more to a larger pool of buyers. Well that's my 2 cents, good luck
1971 911S, 1974 914 2.0, 1999 Boxster, 2003 Boxster, 2008 Cayman S. www.TheLolaRegistry.com "When you think you are in full control, you're just not going fast enough." |
In short $15k on car $7k on engine -$2k for replacement engine = $20k towards ready to drive RSR car And as a bonus you preserved an early S car since the buyer will restore it . Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
Unfortunately it's not an aluminum engine case, in mid year '68 they changed to the mag case and thats what I have. I couldn't get 7k for the engine, it has '69T heads on it, I have the original heads but they need a valve job, it has solex cams and it leaks a lot of oil. I'm sure selling my car wouldn't be a problem but getting another one would. I live in Canada, an imported car has to be bone stock and in perfect condition. I would hate to buy a roller, do the conversion and then not be able to register and insure it. Canada is limited and pricy when it comes to P-cars, a $1500 944 in Cali. would probabily sell for $5000 up here.
'73 914 2.0L |
You are right about the value of Porsches up here though. A $10K USD car is worth pretty much $20K CDN up here, depending on model, condition blah blah blah That all said, there's some good advice up there. A few votes for a restoration, but really it's not a viable option AFAIAC. As far as not liking ST flares goes....from some angles I agree, but not from this angle:
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc. |
A 2.2S is appreciating - keep it, restore it.
Erwin '97 Boxster (sold), '67 911S (sold), '77 911 (sold) Definitive Australian/ New Zealand Porsche Resources |
that could end - or pause for years...
but I still say restore it - it is an S and you can do things to move it back towards stock while driving it for a few years. put any motor in it while you look for an S motor; it wouldn't be the same engine # as was on a CoA (assuming the CoA's are ever correct...); but the car will be worht quite a bit with an S-type motor even if not the original motor #. After all, if your 35 yr old motor finally blew up and you got a new one, couldn't you still win a concours?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Jasper is that your car? I love the flares on the front, thats exactly what I want!! A flare that stays away from the top of the fender leaving the body line intact. The ST flare starts at the top of the fender and slopes down steeply to the wheel opening, the RSR flare also starts at the top of the fender but has less slope to the wheel opening. The reason I dont like the ST flare is because it looks too droopy, the RSR is not as bad. Who makes the flares on the car pictured? What do the rears look like? Anyone know? Ok, now I'm excited!!!
'73 914 2.0L |
Randy, you make a good point. I'm not much of a concourse guy but I can appreciate originality. It's just my fenders and quarters are so hacked up, they are going to require a lot of work either way, flare or no flare.
'73 914 2.0L |
Here you go... (not mine but you wanted to see these pictures right?)
'82 911 SC |
Ayo Irpin, Ukraine!
ST or sell it if you're hung up on the RSR thang. A proper ST flare is the sexiest piece of work period.
Makes the RS, RSR, SC & turbo flares look like crap!
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
dibs on the white fuchs!!
1978 911SC #737 "D" Class Club Racer |
