Timing Question
1980 3.0 SC
Just tinkering here and decided to check timing at 6K rpm. We had initially set timing at 5* BTDC while at idle. Checking it at 6K rpm, we found only 25* BTDC ! Mechanical advance is fully & smoothly functional. Dizzy has dual vac canister with 2 vac hoses. We reset timing to 35* at 6K rpm and it verified with 15* at idle. Had to tweak the mixture slightly and took it out for a spin, it runs smoother and pulls stronger than ever now, even starts quicker. Idle is very stable at 950-1000. Previous exhaust popping on decel now almost non-existant We're wondering if there is any problem with it being at 15* at idle or is everything OK??? Side notes: 02 sensore disconnected, decel valve disconnected. No pinging even on regular fuel. |
I've search many many threads that talk of how to time the motor but still no answer to my question of "will 15* BTDC at idle be OK or will it cause problems?
Surely someone here knows? |
As long as you are convinced that 6000 RPM setting is indeed correct I wouldn,t worry about the idle setting as much. It does seem unusually adv. at idle though.When I had a 3.0 original 1980 motor it did,t like to idle well with alot of idle advance.
I poured back through many threads on this last night and come up with so many different settings that guys are using it's almost null to read it all.
30*, 32*, 35*, etc I need to do a curve of the advance and chart it out then, compare to known chart i guess. Anyone have the advance curve for a 1980 SC ??? |
Spec for your car is
5° BTDC @ 900 ± 50 w/ vacuum detached RoW 23° - 29° @6000 w/ vacuum detached US 19° - 25° @6000 w/ vacuum detached |
Much appreciated Bill.
I guess I need to back her off a little then. Dang, it runs so good @ 35* :) |
as long as it does not DETONATE and u like the way it runs, all is fine.
too much advance=detonation. u will need to richen it up as u said u did. detonation is an engine killer |
| All times are GMT -8. The time now is 04:47 PM. |
