Danny_Ocean's Avatar
"T" (or actually "Y") fitting off of fuel tank vent line?
My car is a '79SC. There is a plastic "T" (which looks more like a "Y") fitting halfway up the fuel tank vent line. This "T" feeds another hose which disappears under the fuse panel then exits, via a metal tube, to the inner fender. There is also a smaller hose (about the size of a vaccuum hose) which heads out and terminates under the front bumper. At either hose end, there is nothing covering them and gas fumes are escaping/accumulating under the front of the car. My (sorta) educated guess is this is remnants of a long-gone vapor recovery/charcoal cannister. Can I remove the "T" and delete these hoses?
Old 11-22-2006, 03:55 PM
ttt
Old 11-23-2006, 05:13 AM
HarryD's Avatar
It is part of your vapor revovery system. You will need a place for air to be pushed out of your tank when you fill it and to let air in when it goes down. You need to resotore this system for your heath and safety.
Do a search for vaopr recovery. Some intersting links to get you started:
1973 emision stuff
Fuel odor, front wheel well
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-23-2006, 10:09 AM
randywebb's Avatar
Removal will cause the fumes to accumulate inside your trunk - very unwise.
charcoal cannister was/is prob. in the RR of your SC
there was a plastic tank that earlier models had under the LF fender for those hoses - you need to find or fab. another one.
PS - you are gonna flunk Calif. emissions w/o it.
Also, you may engine trouble in the mtns. or desert w/o the proper emissions hose setup.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-23-2006, 10:16 AM
Charcoal cannister and vapor recovery tank have apparently been removed by previous owner. Gas fumes are pumping out of one of the hoses when the car is running. I've reviewed all the diagrams, but I'm still not sure how the vapor/vent get from the front of the car to the engine compartment. Does anyone know the location of the hose I should be looking for?
Old 11-24-2006, 06:27 PM
randywebb's Avatar
does this 1970 diagram help?
I think you need one for a 1968 car (maybe 1969)
Jim Sims once posted something about ROW cars dumping their fumes out a certain hose. I'll see if I have it saved, or you can try to pull it up w/ a search.
Old 11-24-2006, 08:30 PM
randywebb's Avatar
Thread with a large # of diagrams that Grady posted
tank ventilation-MFI diagrams
-- but I don't really see what you need, which I suspect is to turn the car into an early config. or into a ROW type car if you want to fail emissions testing.
to Pass, you need to buy a vapor tank from a junkyard; and get a charcoal canister from VW (they make the one the 911 uses). Then hook it all up correctly.
Old 11-24-2006, 08:37 PM
My 78 ROW had the recovery tank in the LF fender. The car had no charcoal canister though. If I find I can convert the car to race w/o this tank, I can send you mine.
-Brian
Old 11-24-2006, 08:45 PM
Randy, the ROW cars dump fuel vapor out a hose through to the tank in question through the LF fender right next to the hole where the lighting wires go. The system has one tank, not a separate one for expansion and vent.
-Brian
Old 11-24-2006, 08:46 PM
randywebb's Avatar
simplified system for race car - not sure if Chuck Moreland ever implemented it...
Need to vent, my gas tank
Old 11-24-2006, 08:48 PM
I have no emissions testing. My car is ROW, but has been "butchered" by the previous owner. I'm not too interested in restoring this feature, just trying to figure out a way to send the fumes to the air cleaner while the car is running.
Old 11-24-2006, 08:52 PM
randywebb's Avatar
Brian,
1. which year ROW cars?
2. You are saying there is only 1 tank and it is in the LF fender? -- i.e. there is NOT a tank up under the cowl (by the tach)? that is where the 2 tnks are on early US cars.
3. Do you know where the hose you mention originates?
Old 11-24-2006, 08:53 PM
Good link Randy, thanks.
-Brian
Originally posted by randywebb
Brian,
1: Not sure, but I know 78-79 are like this.
2: Yes. No tank behind the dash.
3: It originates at the T (Y) which Danny is questioning. It terminates at the LF fender tank.
-Brian
Old 11-24-2006, 08:56 PM
randywebb's Avatar
Danny - (most early cars) have two rel. large dia. fabric covered hoses running back to the engine comp. - those carry vapors to the motor and need to be connected; they are in or near the tunnel
later cars ('75 on?) have the charcoal canister in the engine comp. and may only have one hose - I dunno
Old 11-24-2006, 08:57 PM
OK, thanks. I'll look for them. There are a few hoses in my engine compartment that are disconnected (from something) and blocked off with golf tees. I also found a hose barb that was wide open on the left side of the air cleaner. I blocked it, but now believe it may be the vacuum source for the vapor recovery system. Gotta find another car and compare the two! My car is an absolute mess, thanks to the previous owner's feeble attempts @ maintenance/modification.
Old 11-24-2006, 09:03 PM
How are your brakes? The vacuum hose could be for the MC booster too.
-Brian
Old 11-24-2006, 09:07 PM
randywebb's Avatar
good luck - I wish I'd taken a pic of my evap hose system when I pulled it out of the car...
BTW if those trunk hoses are yellowing then they should all be replaced with special gasoline vapor approved tubing - not normal PVC - it will fall apart quickly.
what's the Bentley say ?? you are lucky yo ahve a car new enough to have a BEntley on it...
Old 11-24-2006, 09:17 PM
Brakes seem fine. Are they vacuum assist? It looks like a manual brake MC to me...
Old 11-25-2006, 08:07 AM
Your doesn't have a big black booster to the front of it?
-Brian
Old 11-25-2006, 12:49 PM
