MMBRAZIL
Guest
Posts: n/a
low rpm, valves ping.
If I drive my car at low rpm, like in traffics, I get valve pinging. When I start driving it harder, at higher rpm, the pinging disapears. Could this be related to my oil preasure? I read 0,3 in the gauge at iddle until 2k rpm.
74 911 2.7l cis
Old 09-11-2000, 11:56 AM
Superman
Guest
Posts: n/a
Try higher octane gasoline. See if this removes the noise.
'83 SC
Old 09-11-2000, 04:02 PM
Intubator
Guest
Posts: n/a
If the higher octane gas doesn't work, check your distributor for proper advance and retard. Sometimes the internal springs and/or the vacuum advance will fail causing improper ignition timing and detonation.
74 911 2.7l cis
Old 09-11-2000, 06:07 PM
MMBRAZIL
Guest
Posts: n/a
IŽll check both...tks guys.
Old 09-12-2000, 06:05 AM
