joetiii's Avatar
Ooh ooh. Engine noise
As a last hurrah, I went out with my 69 3.0 and took along my buddy w/his 930. Try as I might, I couldn't gain any distance in the twisties. Spent most of my time in the 4000-5500 range for an hour or so.
As we headed home coming out of the mountains, I noticed a rather loud slapping noise from the engine compartment. My engine ran smooth, with no misfires and no oil burnining etc. Just a rather loud chain noise from the right side that seemed to get quieter as the revs went up.
Seeing as I just had the right chain tensioner replaced and my 3.0 has guards versus hydaulic tensioners, I'm thinking the ramps or sprocket is getting in the way of a loose chain.
I backed off the pedal on the way home and the noise subsided a bit. When I fired it up this AM. all was back to normal.
ideas?
joe
'69 911 E Targa - aka "RoxiE"
Old 11-26-2006, 06:55 PM
FenderGuy's Avatar
not to scare you but that the type of noise my engine made when it eat a piston...i thought it was the carrera fed tensioners, mechanic showed me otherwise
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 11-26-2006, 06:58 PM
Immature Member
dentist90's Avatar
Did you change the timing chain with the tensioners? Just a W.A.G., but could the chain be stretched to the point where it is contacting an opposite chain guide?
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 11-26-2006, 08:14 PM
joetiii's Avatar
We opened the right cover this summer when we heard a different noise and discoved the stock tensioner had started to come apart. we did not change out the spocket or chain at that time. There is only 8,000 miles on the rebuild. I plan on converting over to carerra tensioners this winter and think that new chain ramps and updated sprockets might be in order too.
joe
Old 11-27-2006, 03:47 PM
