Ok, Dumba$$ question. Will SC distibutor fit 3.2?
Just got a heart attack when i went to buy a distributor cap for my new Carrera... $41???? Damn! I've got perfect 3.0 distributor lying around gathering dust... will it fit the 3.2?
'79 930/934 replica 80 RSR-look(Now in Sicily) 914/6 2.7 (Projekt 908/3) 1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW D-Zug Produkte/D-Zug.com |
No.
Thanks. How often are you guys replacing the cap/ rotor on the 3.2... same intervals as 3.0?
I've never replaced it on my 3.2 because I don't drive it much, but I have had several other Motronic injected German cars, and found that the caps and rotors can go a long time!
I know most here probably over-maintain, which is good for our toys. And this will likely be met with ridicule and scorn. But I've gone 60,000 - 70,000 on my other Motronic cars, and when I took off the old cap and rotor, they looked fine. Not new, of course, but still ok. After replacing, I didn't notice any difference in the way the car ran. If you are adverse to spending the money, and you aren't having any running problems with the car, I'd just maybe pull them, take a look, if they look ok just clean them up a bit, and go on your way. |
Open it up and look inside. If it's still clean and the connections are shiny keep it. If it's dirty and the connectors look rough, replace the whole thing.
MRM 1994 Carrera |
$41.00? try $610.00 for an RSR cap
Robert Currently Porsche less (but the wife has 2) |
I replace mine annually, driving about 12k per year.
$41 isn't even a tank of gas anymore, so to me it's not such a big deal ![]() -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
yeah, i guess i've been spoiled by years of SC tune-ups.
Immature Member
I recently took this out of my car, looking a bit worn so replaced it. I checked the fairly extensive records that came with the car, no record of distributor replacement. This could be the original (180,000 km)!
The reason I suspect this cap may be over 100,000 miles old is that the rotor was seized on so tight that it pulled the shaft out when I tried to pry it free: I was having no running issues at any rpm, just thought it was time based on appearance of contacts inside. If so, these can be quite durable. As always, YMMV!
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
