Stupid A/C question
Hey guys,
This is my first 911. it is a black/black 85 coupe. I searched and searched but i CANT fig out how to turn the a/c compressor on/off???
I get the whole heat/defrost thing, is there a seprate control?
Andrew
1985 3.2 black carrera coupe
Andrew Deihl
adeihl@gmail.com
Old 12-01-2006, 09:59 AM
Senior Member
Should be two knobs on the console. One turns the fan on and the other is the temp control. What happens when you turn these on?
Old 12-01-2006, 10:32 AM
2ndTARGA's Avatar
Andrew:
Here's a photo of the knobs and console Joeaksa was talking about. Hope a previous owner didn't remove the whole thing.
Ron
1996 993 Coupe, Tiptronic, Polar Silver
1973 914 1.7 Marathon Blue Metallic - Sold
1977 911S Targa - Sahara Diamond Metallic - Sold
1975 911S Targa - Copper Brown Metallic - Sold
Old 12-01-2006, 01:01 PM
i will go take a look, i dont really think anything happens. I dont notice an idle drop or anything. I have both knobs though
Thanks for the help guys,
Andrew
Andrew Deihl
adeihl@gmail.com
Old 12-01-2006, 02:24 PM
2ndTARGA's Avatar
Hook a 12v test lamp to the hot wire that is connected to the compressor and see if it's getting power when you turn the temperature switch to full cold. If so, then your compressor or compressor clutch is the problem. If not, it's a problem with the switch, a fuse or a broken wire.
I'm not sure about the '85 system, but if all the wiring checks out you might be out of freon - most A/C systems have a low pressure cut-off that keeps the compressor from running w/o freon.
Good luck.
Ron
Old 12-01-2006, 02:32 PM
I have an issue of when reving or comming to a stop, the RPM's will bounce down as far as 200RPM and then back to 800. I think the compressor is on perminantly.
Andrew
Andrew Deihl
adeihl@gmail.com
Old 12-01-2006, 02:38 PM
kuehl's Avatar
In the center console (in front of the stick) are two knobs.
Right knob turns on the a/c system and controls the three fan speeds.
Left knob controls the temperature of the evaporator coil which changes the vent temperature: turning the knob clockwise is colder, counter clockwise is warmer. Depending upon the evaporator's temperature the compressor will turn on or off.
This link explains much of what you are looking for:
http://www.griffiths.com/achelp/achelp4.html
With the engine off, open the engine deck lid and look at the compressor's clutch on the RH side of engine. A belt turns the clutch pulley. Closest to you is a hub on the clutch. When the compressor is "on" the hub should be turning with the pulley together (what a team!). So, in park, neutral, start the engine, turn the right fan speed clockwise, turn the left hand thermostat knob fully clockwise. If the evaporator's temperature is not satisfied, meaning the evaporator is above 26F-34F nominal (as explained the referenced website above) then the compressor clutch hub should be engaged with compressor clutch pulley and they are turning together.
Now whether or not the compressor is pumping, the refrigerant is flowing or the evaporator fan is blowing air out the vents is another story.
A high or low pressure switch was not stock in the 911 until the 964 came about, however some very early models may have a high temperature cut out switch attached to the drier (not common) or there could be a high/low pressure switch installed as an aftermarket improvement
Usually the RPM's are increased by the DME? when the ac is turned on (correct me experts if I'm wrong), however RPM "bouncing" could be other things (air fuel ratio "AFR") problems, bouncing air flow meter doors, air idler, etc.
Start with the suggested inspections and the follow the trouble shooting suggestions.
Let us know.
Old 12-01-2006, 08:41 PM
