pryord's Avatar
Metallurgists - A little help...
So, the last time I put my muffler and cat conv. on, I thought I would be smart and use stainless nuts and bolts. The old regular steel ones were rusted and required cutting to remove. After only a year, I went to remove the stainless bolts and they are locked tight. All but a few required me to break the heads off. Heck, it's taking me longer to remove these than the old rusty ones.
What's up? Is there somethings about stainless and heat that causes them to bond together?
What should I use this time in order to facilitate easy removal. Is regular steel and "anti-seize" the way to go?
Thanks!
1967 S
Old 12-04-2006, 11:17 AM
Somewhere in the Midwest
MotoSook's Avatar
Did you use anti-seize on the stainless fasteners?
Old 12-04-2006, 11:25 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Titanium fasteners will do the job...!
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 12-04-2006, 11:45 AM
slammed1000's Avatar
Send a message via Yahoo to slammed1000
regular stainless requires anti-seize or it will lock on under heat.
Old 12-04-2006, 11:47 AM
Friend of Warren
The heat will gaul the stainless steel nuts and studs as you have discovered. Either use stainless steel studs with bronze nuts or use regular steel studs and nuts with some anti-sieze.
Kurt V
MotoSook's Avatar
Even with anti-seize the nuts will lock. As a matter of fact they seem to lock "better" with anti-seize! That's why I asked if he used anti-seize.
Old 12-04-2006, 12:03 PM
Zeke's Avatar
Why not steel and bronze nuts?
Old 12-04-2006, 01:51 PM
pryord's Avatar
Nope, I didn't use anti-seize. Steel and bronze sounds like a good idea.
1967 S
Old 12-04-2006, 01:59 PM
On the subject of anti-seize compounds,....
There are several kinds and using the wrong one is akin to not using them at all. :0
1) Aluminum-based
2) Copper-based
3) Nickel-based
Copper & nickel based products are the preferred ones for exhaust hardware or anything that is exposed to extreme heat.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-04-2006, 03:46 PM
Diss Member
Quicksilver's Avatar
Stainless bolts and bronze nuts is a common combination but it you can find copper nuts they work even better.
As far as finding anything other then aluminum anti-seize...
The last time I went looking for copper based anti-seize everyone at the various autoparts and fastener supply houses looked at me like I had three heads. I know that permatex used to make it because I had some but I am coming up short now...
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-04-2006, 04:40 PM
I read in an engineering manual using SS nuts and bolts of a different hardness will prevent seizing.Try a hard grade bolt and soft nut.I've seen SS nuts and bolts seize without heat.
76-911s 80-911sc
Regards Lester
Old 12-04-2006, 05:34 PM
Ken911's Avatar
you need to use the nickle based or graphite based. the copper will also seize, use felpro or locktite n-5000, or n-7000, we used to use the copper based n-4000 several years back on our steam generators and some of the bolts would seize up, and we had to use a hytorque to remove them. now we use n-7000 which is graphite based on the primary side and n-5000 which is nickle based on the secondary side and never have problems. some of these bolts are torqued to 1200 ft pounds and operate for 18 months straight at 574F
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 12-04-2006, 08:14 PM
David's Avatar
Re: Metallurgists - A little help...
Thanks!
Yes
Old 12-05-2006, 03:50 AM
Antiseize source
As is often recommended on this site, to source hard to find hardware, etc., try McMaster-Carr-- www.mcmaster.com.
McMaster has antiseize compounds for most applications.
1973 911-S Coupe
Old 12-05-2006, 04:07 AM
Bland
unclebilly's Avatar
The nickle stuff may also sieze. We used stainless hardware at one point on our ceramic fuel cells (they run at 750°C). We tried all of the commercial high temp antisieze compounds with varied luck. In the end we settled on our own home made concoction that worked quite well.
There are 2 things working against you here:
High temp oxidation which tends to cause the threads to jam together and the fact that the bolts become fully annealed in use (totally soft) so the threads want to gall together when you try to loosen them.
I'm not sure that I agree 100% on the brass nuts because they would be quite weak at operating temp but they would come off nicely once cooled down. If you could get 400 series stainless steel bolts and nuts and use some of the high temp nickel based antiseize (the nuke plant stuff) you will be OK. Other wise just get some good quality un plated steel bolts and nuts and run the nickel antiseize.
Old 12-05-2006, 05:11 AM
pryord's Avatar
Thanks for all the info. Nothing is simple, is it? Off to the hardware store I go...
1967 S
Old 12-05-2006, 05:56 AM
Diffusion bonding of stainless steel fasteners is quite a common problem particulalry if you use an Austenitic Stainless Steel.
Ferritic alloys may be a little better but even then there may be problems.
The tooling used in high temperature materials testing machines suffers with these problems on a routine basis and for many years carbon 'dags' were all that was available but this was messy and not 100% successful.
For the last few years Boron Nitride Dags have been used in this type of applications and have much improved performance and I have been using this type of product for years.
It is fairly readily available and is a white compund and not too messy.
Old 12-05-2006, 08:02 AM
randywebb's Avatar
what is Diffusion bonding ?
are metal atoms diffusing across the boundary??
BTW, the Copper anti-seize is all over the place - I suspect the parts place worker bees just don't know what it is - look for a copper color.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-05-2006, 10:34 AM
