I started to clean the oil crude off of Pistons and Cylinder and I discovered that the P/C are marked with Mahle!? Are the Mahle original equipment for 3.2 Carrera? If so, can I buy stock pistons rings from Pelican part to replace? If not, what rings should I buy?
Thanks in advance John |
Warren Hall Student
Yes, Mahle are OEM. You can buy a set of rings (Goetze) from Pelican for about $150.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
some of them are KS as well.. Its a bonus to have the mahle as now you can boost it with no worries
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Woopee,
How much boost can I crank it up too =) MUhaaaahaaaaahaaaaa Evil laugh. John |
I think there were two OEM's for the 3.2's: Mahle made Nikasils which can be honed and reringed (so you are lucky), and Kolbenschmidt, which made Alusil, which are generally regarded as not reringable, although some people claim success in doing it.
The engine rebuilding forum here has some extremely long and informative threads on this very subject. HTH, ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
![]() If you are going in there anyway, you can do some simple things to reduce C/R further and run a bit more boost for more power, such as C2T head gaskets, or custom JE forged turbo units
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
