Performance Ignition Upgrades?
Are they worth it on my '78 SC? Or do they ask for problems on the old cars? I noticed its a common thing on the newer cars when they are modified with MSD's and what not.
I was considering a new ignition coil, and found this
http://www.***************/productpage.aspx?pid=105133&name=Nology+ProFire+Ignition+Coil
any thoughts on how that would help or worsen the motor?
While looking for a new coil, i stumbled across some HP Plug Wires. I dont see how these can really improve performance but two brands claim it. I found these two:
http://www.***************/productpage.aspx?pid=103397&name=Nology+Hotwires
http://www.***************/productpage.aspx?pid=103588&name=Jacobs+Energy+Core+Plug+Wires
thoughts on these would be appreciated as well.
Let me know if i am straying away from what i should be upgrading on the car, i just thought this looked like an easy upgrade if the statements made are true. If anyone has experience with any of these components let me know.
Ken311
.: 1978 911SC Targa :.
Exhaust/Intake: M&K 1/1, K&N, JM Airbox
Suspension: Bilsteins, Strut Brace, Turbo Tie Rods
Old 12-05-2006, 08:51 PM
Air Medal or two
afterburn 549's Avatar
they seem to work or not / no middle ground...there are lots of mods one is going to a "stand alone" but you have to evaluate your real needs..vs real, and- the cool factor.
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 12-05-2006, 09:48 PM
randywebb's Avatar
zero improvement unless things aren't right with your ign. now
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-05-2006, 10:35 PM
Air Medal or two
thats a so true...I always try to get the big picture, where is my Eng going? / and and piece I buy should fit the new application so as to not to have to do a redo later.
If you unsure of you needs its cheaper not to do anything like Randy says....but if you have 30 yr old plug wires and coil on there....you might consider those "If" your going to stay pretty much stock....Like I say, hate to go back wards and have to renew a new item.TMO
Old 12-06-2006, 07:34 AM
